GT500 w/ Kenne Bell - 810rwhp/745rwtq
Old Nov 16, 2006 | 06:50 PM
317indy
Guest
Posts: n/a
Default GT500 w/ Kenne Bell - 810rwhp/745rwtq
810 HP/745 FT/LB KENNE BELL BIG BORE 2.8H SHELBY GT 500 KIT
On November 9th Kenne Bell made history. Our new 2.8H("H" for 2.0 high pressure ratio) Big Bore Twin Screw kit recorded an incredible 810 hp and 745 ft/lbs(SAE corrected). Our Earl's Automotive test car was 100% stock except for cooler plugs, a Kenne Bell boost-a-pump and optional throttle body and inlet system. That's with a stock fuel system (lines, rails, pumps and injectors) through stock cats and exhaust. No headers, cams, nitrous etc., only the 2.8H kit. All with an ultra efficient, compact and lightweight 2L series Twin Screw. The supercharger itself is so efficient that bolting on the big discplacement 2.8H with the same size stock 3" pulley increased power by 125hp(606 vs 481) over the Eaton 122 (2.0L). Same pulley size - same tune. Only a kit change with 100% stock car. The kits HP range is 568 - 810. Preliminary tests indicate it can make 725 hp on pump gas at 16 psi. The new supercharger is so efficient that 1 psi of boost is 25 hp. Remember the "H" series requires less engine HP to drive, By upgrading pulleys(12-20 psi) and optional inlet components(throttle body and cool air kit) there's plenty of room to grow.
Preliminary testing indicates the Shelby makes 725HP on pump gas at only 16 psi and 810 hp at 19 psi. The unusually high HP output is possible because of the 2.8 H's radical 2.0 internal pressure ratio. Other 2.2, 2.3 and 2.4 Twin Screws use a 1.4 built in internal pressure ratio. The new design Kenne Bell 2.8H consumes up to 40 less engine HP to drive, that means 40 more rear wheel HP at the SAME boost. Discharge air temps is also 30 degrees cooler at high boost levels. These two 2.8H features(less parasitic HP loss and lower air temps) are responsible for it's unusually high HP levels.
Equally important to the overall high effeciency of the kit is the cavernous high flow 1000 hp + inlet and a huge new Kenne Bell dual 75mm throttle body.Both were developed on our new 1000 hp flow bench.
Our goal was to engineer a flexible kit with a compact lightweight, highly efficient - low parasitic loss billet twin screw that would make all the HP 99% of our customers would ever need. 810 hp and 670 ft/lbs at only 2500 rpm is more than enough to exceed the design limits of the stock engine and drive train.
Literature and Tech Tips will be posted on our website on Dec. 15th. or sooner. Next we'll gut the cats and test headers, exhaust and cams on the dyno and drag strip. Earl will be doing all the driving. The "Shelby Tech Tips" will include everything we've learned about the car's fuel system, ignition, clutch, inlet system, calibration etc. along with 50 dyno tests from the stock 444hp / 428 ft/lbs to 810 hp / 745 ft/lbs.
We have 2 months of development time and over 500 dyno runs on the Shelby. It is the most exciting, efficient and insanely powerful production engine we've ever done a kit for. By comparison, our GT Supercar made 710hp with a 2.3 Lysholm and Kenne Bell HCD Drive Conversion with 2 1/2 pulley. The KB 2.8 H Shelby made 810 with the same 2 1/2 pulley, throttle body, tune etc.The heads, cams and CR are also the same for both engines, the Supercar even having a perceived power edge with it's exhaust and dry sump. Yet the KB 2.8H equipped Shelby developed another 100 hp (810 vs. 710). The 2.8H is definitely capable of pumping 800 + HP into these engine. Kits should be available Jan. 15, 2007 or hopefully sooner. Again, our kits are designed so yu can customize the desired HP by selecting the pulley, cool air kit and dual 75mm throttle body. Tuner kits are also available and no problems with the pulley to hood clearance at the lower boost/HP levels. 25 HP increments from 568 - 810 with a direct bolt on on upgrade kit and all stock engine components.
http://www.svtperformance.com/forums...62#post4314062
The first dyno graph is the KB 2.8H Shelby kit vs. Ford GT Lysholm 2.3 kit with same 2 1/2 pulleys, same timing, and same A/F ratio.
The second dyno graph is the same KB 2.8 Shelby kit vs. stock Shelby Eaton 122 with same 2 1/2 pulley, same timing, same A/F ratio.
Old Nov 16, 2006 | 06:57 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
I like those numbers.
Old Nov 16, 2006 | 07:00 PM
GreenBlood's Avatar
God Damn!!!!! That's mean as hell..
VINCE's Avatar
Shorty Director
WOW!!!!! Congrats!!
Old Nov 16, 2006 | 07:08 PM
Phate's Avatar
LOL, that is my friend's car.
Old Nov 16, 2006 | 07:09 PM
317indy
Guest
Posts: n/a
Any plans on taking it to the track to get some numbers out of it? Im really interested in hearing what other plans he has for it...
Old Nov 16, 2006 | 07:46 PM
Phate's Avatar
I'll give him a call and see when he is going to be taking it to the track.
Old Nov 16, 2006 | 08:58 PM
bowtieman81's Avatar
Damn, awesome numbers!
That is really more power than I expected from the KB kit. I was figuring they would see about 725 rwhp, not over 800. Well done, but that car is quite a bit of fun to drive.
Old Nov 16, 2006 | 09:30 PM
LSs1Power's Avatar
Impressive.... I would like to see those kits on forged C5's and C6's.
Old Nov 16, 2006 | 09:32 PM
ChrisUlrich's Avatar
I just want to see that kit on my car!
Old Nov 16, 2006 | 10:38 PM
MEAN LT1's Avatar
I love that torque curve.
Old Nov 17, 2006 | 06:21 AM
unit213's Avatar
Administrator
I caught this at a few 'stang boards. Pretty crazy numbers. Now let's see what
the 3.3L Whipple kit will do.
Old Nov 17, 2006 | 07:09 AM
Somebody09's Avatar
Maybe I should buy a Ford afterall... HP seems so easy with the dark side. Besides, traction, what are the disadvantages?
Old Nov 17, 2006 | 09:27 AM
RealQuick's Avatar
Nice #'s.
Old Nov 17, 2006 | 09:36 AM
smoke20's Avatar
you dont have to have a ford to make that hp , KB put a twin screw on a z06 and had over 650 tq at like 2000 rpm it was sick. had better tq #s than the stang but i think the stang has more hp . maybe someone can find that thread and link it.
Old Nov 17, 2006 | 10:02 AM
Robert56's Avatar
here's one for a C5 that made 850rwtq and 801rwhp, or over 1000 each at the flywheel.
http://forums.corvetteforum.com/show....php?t=1468770
Robert
Old Nov 17, 2006 | 10:07 AM
Somebody09's Avatar
Right, but I'm also looking at how many stock parts the Ford kept.
Old Nov 17, 2006 | 10:12 AM
smoke20's Avatar
i understand its sold "stock" but it is a forced induction purpose built motor , im just saying both eng can and do make great hp with the KB. im impressed by the GT500 with the KB but i will never turn to ford when i got BOWTIE that can and will do better. when you put the KB kit on the GT500 it no longer is stock so i was just giving you some info i read about.
Old Nov 17, 2006 | 10:24 AM
2002/Black/SS's Avatar
that is very true, but imagine how much the blue devil (corvette SS maybe) with the supercharged boost built ls7 will make with just straping on a KB, imagine! i think in the 1000HP range
Old Nov 17, 2006 | 10:36 AM
Phate's Avatar
Should be hitting the track soon. I'll post details when I know more.
