Toyota Tundra truck better because the TV shows it?
President
Gene Norris Buick-GMC Trucks Inc./Norris Auto Group
18170 Bagley Rd
Middleburg Hts., Ohio 44130
There has been a lot of talk about Toyota Tundra's new ads and how
impressive they are. Here are some myths about their spots that I
have found and that should be refuted. Also, they are offering a
"IVC" type program on Tundra to help with sales.
I would guess all of you have seen the ad where the Tundra pulls a
trailer up a steep grade (a 'see-saw'), and then barrels down hill and
locks the brakes up just before the end of the ramp. Many of you have
commented on how well done the spot is visually. However, here are
the actual facts to share with people:
1. The V.O. at the beginning of the spot says...."It's tough
pushing 10,000 lbs up a steep grade". Myth: Toyota would like the
audience to believe the trailer is 10,000 lbs. Fact: It's a 5,000 lb
truck pulling a 5,000 lb trailer. A little slight of hand? You bet.
2. Then, on the way down the grade, the camera zooms in on the
brakes as the vehicles comes to a screeching halt just prior to the
end of ramp. Next time you see the ad....look for the 'mice type'.
It indicates the trailer is equipped with electric brakes.
Fact....the electric brakes stop the trailer -- not the truck. A
3. And why does Toyota have bigger brake pads? They need
them....their truck is heavier. Stopping distance between our truck
and theirs is virtually identical. And why does Toyota have a 6 speed
transmission? To improve their fuel economy....which is still 2 mpg
less than ours.
4. And don't forget....their big V8 has one axle ratio -- a
4.3. Suck fuel much? Our trucks offer several axle options to
optimize towing and fuel economy. Bottom line: OUR TRUCK IS BETTER!
Spread the word.......we can all make a difference.
Or how they compare their largest, most powerful engine to the mainstream GM offering instead of the 6.2 or even 6.0.
Or the tiny rotor they show you on TV that is clearly not from a 1/2 ton GM even though that is who the ad is directed at.
Even the import biased magazines are putting the Chevy ahead of the Toyota, 3x so far.
Also, Toyota wants to talk about trailering,does anyone know why they don't offer a 3/4 ton.....or a 1 ton?!PLEASE!!Toyota stands no chance in this battle.We also have a 5 year/100,000 mile factory warranty.
And besides trailering,power,and brakes,drive these trucks,guys.The GMC is WAAYY nicer riding,and way more comfortable.
So,as far as I'm concerned,Toyota can suck it.
The only bad thing is, it doesn't matter what you or the mags say, people always believe what they see on TV.
Hopefully when more of the 6.0L and 6.2Ls make their way out there, poeple will see the truth.
Hopefully when more of the 6.0L and 6.2Ls make their way out there, poeple will see the truth.GM 6.0L + DOD + 6 speed = market success.
And if they implement more Cam in block VVT it will just be icing on the cake.
Here are all the Toyota Tundra commercials discussed above.
TundraCommercial
http://www.edmunds.com/new/2007/chev...0hd/index.html
They list the standard motor as a 6.0L
I'm not in the truck market yet...but I was just stating that would be my decision. I'm not sure how I feel about the new 07' styling.
I'd take a 2500 HD 6.0 over a Toyota Tundra anyday....
