1983 monte carlo SS LSX swapped
Year: 1983
Make: Chevrolet
Model: Monte Carlo
Price: $12999
Mileage: 20
Location (State): NJ
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
83 Monte Carlo SS LSX Swapped heads/cam
-car is a true SS
-fresh built 5.3 LM7 motor
-243 heads ported/polished/milled down to raise compression with .660 valve springs shimmed
-COMP CAMS 232/234 110LSA .595/.598 cam
-LSX truck accessory drive
-Holley intake manifold
-Holley 670 carb with electric choke and vacuum secondary
-vacuum pump with comp cams vacuum canister
-1-7/8 Long Tube F body Headers into a custom X-pipe dual exhaust thru (2) 3" black widow widow maker exhausts dumped by the axle
-MSD LSX box
-new plugs, wires, coils etc;
-new gas tank
-champion 3 row radiator
-holley fuel pump/ regulator
-brand new (20 miles on it ) hughes performance TH350 Reverse manual valve body transmission
-hughes GM 30 HD torque converter 3k stall
-custom auto meter shadow box/gauge cluster
-a/c delete heater box
-new blower motor & resistor
-new window motors and door lock actuators
-new B&M pro ratchet shifter
-new white vinyl pro car rally seats (match factory rear seats and blue/white factory interior
-all exterior lights work (headlight, taillight , blinkers etc
car has minimal rust, frame is strong painted engine bay with chassis saver before putting drivetrain in
car is on wheels with brand new tires, rear tires are MT ET STREET drag radial
car is FAST
The interior that has to be put back in is the factory GM blue/white and blue carpet and brand new pro car white vinyl rally seats, the car has 1 seat in it and you can drive it
what the car needs is a carpet, to bolt the seats in (driver seat is bolted in) put the rest of the interior back together, a fresh paint job and to be driven !
asking 12,999 slightly negotiable I am into this car for over 15k so no low ***** please text me at show contact info test drive for serious buyers
don't need to sell it just testing the waters... my loss is your gain !
message me on here or text me (917)-780-2043
willing to trade for LS f-body car
video of the car running /doing a pull sounds mean and fast
bump bump ! I am open to clean trades like an f-body or c5 valued roughly at the same price (would give to my father) or 4x4 cummins or DMAX (clean no rust)
this is all pending inspection of course
