2010 Camaro 2SS RS Cammed 11K FIRM
Year: 2010
Make: Chevrolet
Model: Camaro
Price: $11000
Mileage: 150000
Location (State): SC
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Here's what the transmission is doing if anyone wants to know:It drives and shifts just fine it's on the inital takeoff you have to get the rpm up a bit higher before the vehicle moves (2800-3000rpm) from there it'll drive until you stop at a stop light then at times it cuts off. As I've said numerous times it may be the tune especially with a new stall in it but I cannot confirm. Also you can see it run for as long as you'd like you can even drive right in the yard if you'd like but it has no insurance on the car any longer as I'm not driving it.
Approx 530WHP based on last tune at 498WHP before a few modifications were made on nitrous this is a wet shot that per reports shoots a true right at 150HP so approx 670WHP with slight losses on spray. If you get the transmission corrected rather it be just the tune needed or a new transmission not sure which however this transmission (if not fried) is built with shift kit and staged internals, I cannot be certain if the builder I used (silly me let him do it outside his transmission shop to save money) did it properly or not. It had the parts from the following website installed:
http://www.brtperformance.com/6l80l2.html
Mod List:
Nitrous:
Nitrous Outlet 102mm Fast Intake 2010+ Plate system
150 wet shot of nitrous with purge and warmer
Nos Mini Progressive Controller ( set to spray a 75 shot then come in with the rest of the 150 a second later)
Button that controls it all in the cup holder
1 Bottle
Head work/Intake:
CNC Ported Polished head and valve job from Texas Speed
Titanium retainer for PRC Dual Spring
PEP Spring Seat
PRC Valve Seal
Dual Valve Springs
Fast LSXR Intake Manifold for LS3... Spacer kit for stock ls3 fuel rail
Vmax ported and polished LS3 Throttle Body
Cold Air Inductions air intake
Cam:
DoD delete kit and all other necessary pieces to convert over in preparation for your VVT cam including valley cover, 7.40 chromoly pushrods, non afm lifters, cam phase limiter the only thing not used was LS2 Chain Damper
Texas Speed L99 VVT-4 camshaft
Exhaust:
Texas Speed 1-7/8" Long tube headers with offroad connection pipes/no cats
Only running 2 O2 sensors
Borla Atak Catback Exhaust for the L99 Camaro
Gears/Transmods:
GM 3.91 Gearing in rear diff with positive traction mod by JRE
Built 6L80E transmission with shift kit and serviced with Royal Purple
Circle D Triple Disk 3600 stall converter
Aux Transmission Cooler
Royal Purple Trans Fluid
Wheels/Tires:
2 sets a little curb on some of the wheels
1 set stocks with stock tires on the front, rear are on newer Nitto NT555R's
2nd set all street tires general Gmax good tread from what I remember this has been sitting a while
Bad:
not sure if transmission is good stall is BRAND NEW seen limited signs of shavings when swapping out to new stall after recommended was built by local transmission guy and then tuned feels like it's locking up incorrectly may be a tune issue
AC isn't blowing right now it all discharged all freon when pulling the engine and it had gotten to the point I've already removed the insurance from the vehicle so.... what race car needs AC? haha just needs a charge to my knowledge
This is my "giving up on a project sale" I don't want to see it torn apart otherwise I'd part it out someone that wants to part it out may make a fair amount.
If you want any pictures just message me (803) 899-0625 my friend is about to trailer it to me in Columbia, SC for sale and then I'll have new pictures.
It's been a GREAT car less than 4k miles since the build 150k on the body/cluster.
It's time to move on I don't really have the want to spend more money on it could simply need to be retuned after swapping from the single disk 3200rpm Precision stall or it could need to be swapped out with a new trans and this one be toast.
Feel free to drop me a message on here or (803)899-0625 may consider trades but more interested in cash. $13,000 FIRM WILL NOT BUDGE
Oh and if it's important it's black leather with a sun roof and dark blue exterior
Few pictures can be found on :
https://columbia.craigslist.org/cto/...670828729.html
It isn't in "perfect condition" but it's in good condition body wise. Thanks!
Hm... I'm not quite sure why it keeps doing that I can't fix it.... I'll attempt a bit later for now there are good pics in the craigslist ad as well as I can gladly text you some 8038990625 thanks!
