1969 Camaro Tripple Black Big Block
Year: 1969
Make: Chevrolet
Model: Camaro
Price: $65000
Mileage: 100000
Location (State): GA
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
$65,000
Located in Cumming GA.
This car is just a monster, clean inside and out. No rust!. Its been built over the last 5 years with only the best parts available listed below. I wish I could keep it but its time to move on to the next car. Engine and trans only have 3k on them. Thanks for looking!
Options:
GM 502 Big Block
Eagle 4.250 1-piece rear main seal rotating assembly
Moroso Gen V Kick out pan
Comp Cams billet timing set
Comp Cams billet front cover
Dart 310 Aluminum heads (not ported)
Comp Cams stainless valves
Comp Cams guide plates
Comp Cams high tech screw in studs
Comp Cams high tech pushrods
Comp Cams 928-16 valve springs
Comp Cams 741-16 Steal retainers
Comp Cams 611-16 steel keepers
Comp Cams 1120-16 high tech stainless rockers
Comp Cams Custom Cam CB3370/3371 HR112
248/254 @.050
.646/.646 Gross lift
112 LSA
Comp Cams 887-16 Pro Magnum Hydraulic roller lifters
Headman Ceramic coated headers
Weiland Team G low rise single plane manifold
Demon 750 race series carb (flows 930)
GM performance valve covers
MSD pro billet distributor
MSD 6AL Ignition box
MSD blaster SS coil
MSD 8.5 super conductor wires
Made for you wire looms
Vintage Air front runner with Stewart custom big block water pump & 110 Amp Alternator
Mallory 140 fuel pump
Areomotive billet fuel pressure regulator
Areomotive fuel filter
Detroit Speed quick ratio steering box
Detroit Speed power steering pump with custom line kit
Magnaflow Stainless mufflers
3” Custom exhaust
Richmond 5 speed with long shifter
Autometer 2 1/16” Sport Comp gauges
Autometer 4” sport comp tachometer
QA1 10 way adjustable rear shocks
QA1 10 way adjustable front shocks with coil overs
Cal tracks rear suspension bars
3.43 12 bolt Moser rear end with chrome cap
4 point roll cage
