2000 Camaro SS, low 8 sec car, 1138RWHP, ready to go!! SOLD
Year: 2000
Make: Chevrolet
Model: Camaro
Price: $42500
Mileage: 29000
Location (State): MO
Color: Red
Body has around 29k miles on it now. 980 miles on the entire build.
Holley Dominator efi
7" Holley digital dash w/gps speed
370ci 6.0L w/ forged internals
Custom Turbo Hydraulic Roller Cam
Trick Flow Fast ‘as cast’ 220 cylinder heads
Vic jr intake and elbow
Moroso oil pan
92mm throttle body
Custom alternator bracket
Griffin radiator w/shroud and dual spal fans
Th400 rvmb, pro brake, billet hub, good for 1500hp, atf speed converter bypass valve
Reid roller bearing tailshaft
PTC 9.5 Torque Converter
B&M Outlaw shifter
Dual pass cooler with fan
3" steel drive shaft, strange hardened yokes
Deatchwerks 2200cc injectors
Fuel hat w/ 2 walbro 450's
-8 ptfe feed and -6 ptfe return
Aeromotive FPR
Billet catch can, -10 lines
Garrett GT55R94MM billet, ball bearing turbo
Custom 2.5" hot side
Custom 4" cold side
6" chiseled performance intercooler
Custom tubular mount behind bumper
Bmr turbo k member
Bmr tubular upper and lower a-arms
Bmr solid motor mounts
Burkhart tubular spindles
Flaming river manual rack
Bmr sub frames
Bmr Extreme short body mounted torque arm
Strange adjustable coil overs in front
Strange adjustable shocks in rear
Bmr drag springs in rear
Bmr adjustable anti roll
Bmr adjustable pan hard bar and brace
Bmr adjustable lower control arms
bmr relocation brackets
travel limiters
Strange s60 rear end w/3.55 gears/spool
Strange race brakes front and back
Strange manual master cyl and proportioning valve
10 pt Chrome Moly tig welded cage, certified 8.50, current tag
Kirkey seats on racecraft mounts
17" Racecraft wing and 2pc deck filler
White launcher parachute
Parachute cable and lever
White cam lock harness
Weld 17" alumastars w/ Mickey radials
Weld 15x10 rts w/champion beadlocks on 275/60 pro radials
VFN Sunoco hood
Racecraft dzus rails
Car is tuned on e85 on 25psi at 1040rwhp
Has made 1138rwhp on 29psi
It runs and drives around town like a stock car, never gets hot. It cruises at 70mph at 3k rpm,
will trade for old GM muscle, radical street legal cars, LS power, something of NICE quality, No JUNK!!
Im sure I'm missing a bunch but that's the basics
Race weight w/ 205# driver is 3520#.
Ready to go, needs nothing. Just in time for race season!
Garrett turbo is BRAND NEW, has 1 hit on it.
Price is pretty solid!
Serious only!
314-four-five-two-66-three-nine
Call or text
