07 ZO6 Fully Built 450ci 11.9cr RHS Block, Mast heads, Rpm L7 TR6060, 30k+ in parts
Year: 2007
Make: Chevrolet
Model: Corvette
Price: $40000
Mileage: 50000
Location (State): MO
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
450CI 11.9CR 700+hp RHS LS Aluminum Race Block, Callies compstar forged crank with Arp main studs and Callies H-beam forged rods with Arp 2000 rod bolts, Wiseco 4.165 -2.8cc forged pistons, Clevette bearings throughout, Ls9 oil pump, Cam Motion custom grind cam 248/266 .650/630 112+3, Comp timing set for rhs block, Comp hdy link bar lifters, Comp hi-tech chromemoly push rods, oem rockers with comp trunion upgrade, ARP head studs for 6 bolt heads, Mast Motorsports black label 305cc ls7 6 bolt heads pac springs, stainless valves, 70cc chamber, billet rocker rails, Fast LSXR 102 intake full ported, Nick Williams 102mm intake, Holley billet fuel rails, LS9 injectors, MSD plugs, oem coils, ATI balancer, Vararam ram air intake, Pfat motor mounts
Clutch:
Monster stage 3 single disc with light weight 18lb flywheel and remote bleeder.
Transmission:
RPM Level 7 TR6060 with ZO6 gear ratios and cryogenic treated
Exhaust:
Stainlessworks 2" LT headers with catless mid pipes, Corsa catback
Cooling:
Dewitts radiator with upgraded spal fans, 160 degree t-stat
Wheels/Tires:
Nitto invos stock size 3/4tred left, oem wheels that have been powder coated black with red pin strip
Body:
has had 3m clear bra since day 1 on the front and sides, it does have very few little rock chips else where that you can hardly see paint 8.5/10, Carbon Fiber hood plus i still have the stock one thats a 9/10. 5% window tint all around
Interior: 1
00%stock cept loyds floor mats, has HUD and bose NAV, no cracks tears or scratches anywhere 9.2/10
30K+ in parts alone ive put into this build. Brand new fully built engine and transmission and all bolton's have less than 1000 miles cept the corsa catback car makes 585/544 at the wheels and is still very steetable and comfortable crusing down the hwy with this big cam.
Has plenty of torque thought out the rpm range. Body has 50XXX miles on it, everything works as it should with no issues. The only reson im selling is to get more involed with offroading and travel. Im asking 45K might be willing to do some trading with cash on top
All work was done by Wes Choate @Sho-me speed in Ozarks, mo.
Can text or call any time 417-496-4337 Dann
Email Danngto@gmail.com
That Z06 is sick period. The amount of money it took to put this car to this level is crazy and I'll bet it will make ALOT more then the posted rwhp, as its a very detuned streetable tune and would inject a good amount of power adders. I don't see any shortcuts or any area left out. Good job.
I've been holding off actually calling you trying to figure out logistically the best way I could do this. I live in Las Vegas about 1500 miles away. It would probably be around 1000 to ship the car. What's your zip code so I have a better idea of where you live?
my zip code is 65604 i live about 20miles west of Springfield Missouri
thats about 20 hours away, not to bad. would you trust the car to make the 1400 mile drive back to vegas? That would be the best way for me. fly in on a friday then drive back home that weekend. flights are really cheap. Also is that a standard deck block? was it also changed to wet sump?
yeah.. sometimes i forget its winter...lol its been in the mid to high 70s here for the last couple of weeks. i've got to move some money around and ill be in touch. how far are you from springfield airport? the car has been for sale for around 5 months. what do you think is keeping people away. stock 07s go for around 35k
and priced to sell i think. Ive had alot on people trying to get it for low/mid 30's heck i have 33k in parts alone not including 5k in machine work and labor and i will not sell it for that and others wanting lower mile cars but as u can see all the parts on have about 800miles on them now. Not sure why it didnt sell really fast. Its also a 2 owner car and 0 accidents/claims
