BorgWarner S480,102 TB, Turbo Smart Waste Gate and Blow off valve NEW!
Category: Engine - Power Adders
Price: $1
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): PA
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
Borgwarner S400SX4- 80mm with Race Cover T6 1.32A/R
750-1250 HP Turbo
Compressor Flow over 120 lb/min
Turbo Features:
-Twin hydrodynamic journal bearing
-Extended tip technology compressor wheel
-Twin Scroll turbine housing
-Adjustable compressor and turbine housing orientation
-Compressor cover recirculation grooves
Compressor wheel inducer: 80mm
Turbine wheel exducer: 96mm
Compressor Inlet: 5.51
Turbine A/R: 1.32
Turbine Inlet: T6
Turbine Outlet: 5.75
Comes with billet out let fitting and 4an inlet fitting,
$1000 shipped!
Feed/return lines with block fitting SOLDDD
Turbo smart 60mm waste gate. Everything is included but lower flange. $460 shipped
Turbo smart 50mm blow off valve $220 shipped I can include the section of intercooler tubing that has the receiver flange on it. 4" tubing
102mm Billet throtttle body with Vibrant 4" quick release clamp, I'll include the receiver end of the flange with a extension of 4" intercooler tubing that has a thread IAT bung tig welded on also. SOLDDDD clamp alone is $140!)
GM 2 bar map sensor $40 shipped
4102181620
