Z06 LS6 Mass Airflow for LT1 & LT4 engines
Category: Accessories
Price: $85
Location (State): DE
Item Condition: Used
Engine: LT1/LT4
LS Engine?: Fits LS Engine
NOTE: This is NOT a stock replacement part! It's a genuine Delphi OEM GM component that has been modified for racing applications.
This is a drop in part that has been already been pre adjusted for LT1 & LT4 engines 1993-1997. I will also include the wiring harness adapter LT1 to LS1 styled harness that retails still for $29.99 with the MAF.
This is a drop in item that adds more airflow to your vehicle that can result in additional horsepower. I ran this on my engine as pictured in this listing it was a noticeable improvement over the stock MAF unit especially when you have a Cold Air intake to go along with it.
I've ran this unit both with the SpeedInc tune placed on it when the engine was stock and with a custom PCM Engine tune after further modifying my engine.
The performance of the Z06 MAF is helpful with basic bolt on cars and heads and cam cars.
Why and I selling this part?
I'm parting out my racecar if you can tell by some of the key components missing in the engine bay picture. This MAF unit was well taken care of and kept clean in the time that I used it. It is a used part that may have some scuffs or dings mainly from removing the intake to work on the engine.
For this to work on an LT1 physically it's a larger MAF sensor 85mm and you'll need larger intake ducks to accommodate it.
Technically it's like the Granatelli LT1 MAF a plug in upgrade but easier to tune since it's an original GM component that's better calibrated. I'm not sure what the adjustments SpeedInc did to them specifically but just adding on a stock non tuned Z06 MAF will throw off the stock PCM's calibrations causing the car to run rich and sluggish.
