Notices
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
2006 gto
Old 02-20-2017, 05:14 AM
Schnutsy's Avatar
Default 2006 gto
Year: 2006
Make: Pontiac
Model: GTO
Price: $16000
Mileage: 79000
Location (State): NY
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
Built GTO for sale. Car has 79,000 miles, came from Ohio. Clean title, very fun car just no need for it anymore. May only entertain certain trades.
Engine
-6.0L LS2 built by BES racing egines
documented with receipts
-BES CNC ported 243 heads
-Eagle H Beam Rods with ARP 2000 bolts
-Custom Diamond Pistons, -1.6cc
-Melling M295 Oil Pump
-Double Roller Timing Chain
-Cometic 0.036 Gaskets
-PBM Hydraulic Lifters
-ARP Main Bolts & Head Studs
-Durabond Cam bearings
-Clevite Main/Rod bearings
-LGG6X3 Cam Measure at 236/245 110.5 LSA
-Comp Forged Pushrods
-Patriot Valvesprings & Retainers
-ATI Damper Pulley
-Fast 102 Intake Manifold
-Nick Williams 102mm Throttle Body
-XAIR Over The Radiator Cold Air Intake
-Black Powder Coated Valve Covers
-Meziere Electric Water Pump
-KATECH Belt Tensioner
-Pacesetter 1-3/4" Long tube Headers
-Ron Davis Aluminum Radiator
-Nitrous outlet 102 plate kit with bottle heater, remote opener, standalone fuel system, purge (never been used)
Engine build has approx 8,000 miles on it
Engine has always ran Amsoil Dominator 5w-20
Fuel
-Stefs Fabrication Aluminum Fuel Cell
-Holley Pre Fuel Filter
-Holley 12-1600 Dominator 180gph twin fuel pump
-10AN stainless braided feed lines from trunk
-8AN stainless braided return line
-Weldon Post Fuel Filter
-Trick Flow Fuel Pressure Regulator
-FAST Fuel Rails
Drivetrain
-Factory T56
-Fidanza Flywheel
-Centerforce Clutch
-OEM Slave Cylinder w/ Speed Bleeder
-Tilton Master Cylinder
-Driveshaft Shop Aluminum 1 piece driveshaft
-Motive 3:91 Ring/Pinion
-Harrop Diff Cover
-Billet Aluminum Engine Mounts
-SCSS Semi Solid Trans Mount
Rear end always ran Torco Fluid with Friction Additive
Interior
-Custom 6pt Welded in Roll Cage painted battle ship grey
-Gutted/Grey Painted Rear Interior
-Full front interior with carpet and floor mats
-Nardi Suede Steering Wheel with custom one-off steering wheel adapter
-Pillar and Center Gauge pods with Autometer Phantom II Gauges
-Oil Pressure (only one hooked up), Fuel Pressure, Wideband, EGT, Nitrous Pressure
-Rear Spare Tire Well has been cut out, and an aluminum plate installed
-Battery Relocated to trunk in a Taylor Battery Box
-VZ cluster mod. Chris White unlock with white faces and red needles.
Exterior
-Holden/Vauxhall Front End Conversion
-Custom ABS Splitter w/ Support Rods
-Holden Tail Lights
-Rear Bumper Cut Out
-Borla XR-1 Mufflers with turndowns and Spintech X pipe
-Wing Removed, holes plugged with grommets
-Stock Side Skirts
-Pedders XA Coilover Suspension all around
-Fenders/Quarters are rolled/pulled
-18x10/11 CCW 3 piece Classics
-Also have 15x9 Weld RTS wheels with 275/50/15 MT ET Streets
-Weight is around 3200 pounds.
Only issues with the car are as follows:
-All AC components were removed from the engine bay
-The glovebox has a broken clip
-Battery has a parasitic draw that will drain the battery if it sits over a week.
Car has a circuit breaker for the battery I got in the habit of disconnecting when
the car sat for several days.
Message me for additional information or with any questions
Attached Thumbnails 2006 gto-gto-1.jpg   2006 gto-gto-4.jpg   2006 gto-gto-5.jpg   2006 gto-gto-6.jpg   2006 gto-gto-7.jpg
Old 03-05-2017, 05:57 AM
Schnutsy's Avatar
bumpttt
Old 05-26-2017, 06:50 PM
Schnutsy's Avatar
bumping this up
Old 07-27-2017, 03:43 PM
Schnutsy's Avatar
bumpttt
Old 07-30-2017, 06:38 PM
Schnutsy's Avatar
motivated seller
Quick Reply: 2006 gto
