Huron Speed CLEARANCE V2 T4 Kit w/ Comp Billet 74/83, WG, BOV, etc
Category: Engine - Power Adders
Price: $2750
Location (State): MI
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
This system was used and ran for 1 complete season. Very low miles, ran on 8-10 psi. Entire kit was all tore down, sandblasted, and re-coated. All coating was just completed and fresh. Turbo has no issues, housings were just freshly re-coated to match the kit. Being used this kit is sold as is. There were no issues when pulled from the car, everything was re-coated as noted above.
V2 T4 Kit for 98-02 F-body
-Includes:
V2 Stainless .120 Manifolds *CERAMIC COATED*
V2 Stainless .120 T4 Crossover 44-46mm WG flange, and O2 bungs *CERAMIC COATED*
V2 T4 3″ downpipe *CERAMIC COATED*
V2 T4 3-piece Stainless Cold-side. Drilled IAT Sensor hole *Powder Coated Metallic Silver*
Comp CT43 Billet, 3BB 74mm compressor, larger 80/83 turbine wheel, T4 1.00 a/r housing. Turbine CERAMIC, Compressor Powder Coated!
HS-44 wastegate
XSPower 50mm BOV
All specific Couplers/Clamps
Turbo Blanket, Oil-Lines, Air Filter all included
Satin Black coated BMR Upper Radiator Support
Clearance Item!
*All clearance items are here due to being left over old stock, something a customer traded in to upgrade to a newer/different kit, or something left over from product development.
*Clearance items do NOT carry a warranty, and may come used, with scratches, or other minor flaws and with this we will do ur best to describe the clearance item as accurately to you as possible!
*Clearance items do NOT come with hardware unless otherwise noted in the description below
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
__________________
BumP!
__________________
This is the same kit design as if you ordered new from our website, here are some cold-side photos attached for you!
__________________
