2002 Camaro SS 70k miles $19k
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $21000
Mileage: 70650
Location (State): OK
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
2002 camaro SS
70,800 miles on the car
only 1000 miles on the engine
I have all the receipts from the build over 70k invested in this car that Futral Motorsports built
Iron block 408
Manley Crank
Callies Rods
Coated Diamond Pistons
King main and rod bearings
Futral custom grind nitrous cam
PRC 237cc Heads
LS9 head gaskets
Yella Terra roller rockers
Caddy race lifters
Mast Motorsports Single Plane ported Intake
Accufab 4500 throttle body
Electric water pump
Alternator relocation bracket
TSP longtubes
Nitrous Outlet Stinger gen 3 plate kit
Nitrous Outlet Stand Alone Fuel Cell
NOS Mini Progressive Controller
Lingenfelter Timing and Launch controller
Walbro 255 fuel pump with hot wire kit
Built TH400 with hipster brake
Yank 3800 nitrous stall converter
40k trans cooler
Hughes SFI flexplate
Moser 12 bolt with 3.42 gears
Moser diff cover
Spohn body mount torque arm w/DS loop
UMI lower control arms
UMI panhard bar
BMR extreme drag bar
BMR tubular front k-member
UMI drag upper and lower a-arms
Spohn manual rack w/bumpsteer kit
BMR radiator support
Strange Race brakes on all 4 corners
Strange manual brake master Cyl
ABS delete
Strange front struts
Strange double adjustable rear shocks
Midwest Chassis front and rear bumper supports
6pt chrome moly cage tied into subframe connectors
VFN extended pin on cowl hood
Billet Specialties Street Lite wheels
Full paint correction and ceramic coating
located in Oklahoma City, OK- $19,000 pm for more info
6 point chromoly cage thru floor to sub frames with swing outs. Full interior, no ac or wipers. Excellent street car, has been 5.4x’s on 300 shot. Will handle 400 shot.
Iron block 408
Manley Crank
Callies Rods
PRC 237cc Heads
LS9 head gaskets
Caddy race lifters
Electric water pump
TSP longtubes
40k trans cooler
Moser diff cover
UMI panhard bar
ABS delete
