Notices
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
2002 Trans Am WS6 6-Speed 59k Miles
Old 01-17-2018, 10:03 PM
ChrisSingh90's Avatar
Default 2002 Trans Am WS6 6-Speed 59k Miles
Year: 2002
Make: Pontiac
Model: Trans Am
Price: $14000
Mileage: 59000
Location (State): NY
Color: Silver
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Up for sale if my immaculate 2002 Pontiac Trans Am WS6! This post will be a little long, but it will detail everything you need to know about me and the car.
I bought, and have owner this car, since March 19th of 2013. I purchased it from the second owner with roughly 50k miles. It now has around 59,000 miles (And will go up slightly as I am going to try and take it out and enjoy it before it's sold). As you can see, I've driven it less than 2k miles/year. It's never been a daily driver; it was always my weekend toy. It's ALWAYS been garaged kept AND covered with a California car cover. To say the car is in immaculate condition in an understatement. Oil was changed once a year (Since I'd never meet the mileage requirement) with Mobil 1 10W-40 and a Wix filter. Car passes NYS inspection every year with flying colors.
I am selling the car because unfortunately I do not use it much anymore; I've probably only put like 600 miles on it in the last year. I bought an e39 M5 last year, and my passion and attention has been put into that car. Currently the Trans Am is stored in my mother's garage in Deer Park, N.Y.
It's a full bolton LS1, the valve covers have never been taken off and the engine has never been modded internally. If you are looking for a clean car that was never butchered, this is the car for you. I recently replaced the rear tires since it needed it. I put only the best, Michelin Pilot Super Sports. They don't even have 300 miles on them.
ALL common f-body issues addressed.
-No Dash Panel Cracks
-No Door Panel Cracks (I did the mod to loosen and replace factory staples that are too tight and cause this problem)
-No T-Top leaks
-Preventatively fixed the passenger side window motor with the auto trix rewire kit.
-Replaced the sail panel with one from a pre-98. Pre-98 cars used a different glue and don't eat through the paint and bubble like 98-02 cars! You can park this car in the sun all day and the sail panel looks perfect!
-Replaced headlights gears with aluminum gears (Plastic gears strip, common problem).
Dyno'd 330WHP and 355WTQ @ JTM Motorsports on 7/14/13, this was with the headers and ported TB, but no tune.
Engine ($1,237.51)
5/22/11 - SLP Performance FloPac Cold Air Intake - $333.70
8/27/12 - SLP 160* Thermostat - $44.95
5/13/13 - NGK TR55 Spark Plugs - $19.04
6/3/13 - POTZ Ported LS1 TB & MAF ends - $124.94
9/17/13 ASP 10% Underdrive Crank Pulley/Harmonic Balancer - $82.40
9/17/13 - Gates K060760 Serpentine Belt - $19.60
11/13/13 - Granatelli Solid Core Spark Plug Wires - $113.30
3/11/15 - Frost Mail Order Tune - $166
5/4/17 - Mighty Mouse Solutions Catch-Can - $266
5/8/17 - DEI Titanium Spark Plug Boot Protector Sleeves - $67.58
Exhaust ($2,077.24)
8/27/12 - ARH 1 7/8" Long tube headers, with their high flow catted Y-pipe - $1,410.25
8/27/12 - Stage 8 Locking Header Bolts - $37.99
4/10/13 - C5 Corvette Z06 Upstream O2 sensors - $106.82
5/13/13 - GM Exhaust Manifold Gaskets (Removing headers to install Poly motor/trans mounts) - $25.74
8/13/13 - Stainless steel O2 Plugs (Rear O2 Sensor Delete) - $9.50
9/17/13 - ASP 10% Underdrive Crank Pulley/Harmonic Balancer - $82.40
11/7/13 - SLP Loudmouth II Cat-back - $359.95
11/18/13 - Dual/dual Stainless Steel 3.5" Exhaust Tips $99
Drivetrain ($1,567.72)
4/13/13 - Tick Adjustable Master Cylinder - $324.99
5/13/13 - GM LS1 Slave Cylinder - $119.99
5/13/13 - Tick Performance Remote Clutch SPEEDbleeder - $49.99
11/5/13 - ARP Pro Series Flywheel Bolt Kit - $32.95
11/5/13 - ARP High Performance Series Pressure Plate Bolt Kit - $17.95
11/5/13 - Monster Stage II Clutch W/ Lightweight Billet Steel Flywheel - $729.99
5/25/15 - 2x Red Line 75w-140 - $37
5/25/15 - Timken Axle Seals - $9.26
5/25/15 - FelPro Diff Cover Gasket - $4.99
12/11/16 - MGW Shifter - $209
12/11/16 - Tick Performance Bronze Shifter Cup - $33.61
Suspension ($2,486.43)
4/24/12 - Front Koni Double Adjustable Struts - $530.88
4/24/12 - Rear Koni Double Adjustable Shocks - $291.20
4/24/12 - Strano 1-3/8" Tubular Front Swaybar - $189.99
4/24/12 - Strano 7/8" Tubular Rear Swaybar - $179.99
4/24/12 - Strano "White" Lowering Springs - $224.10
8/27/12 - UMI Chromoly Front Strut Tower Brace - $104.49
3/31/13 - BMR Rear Control Arm Relocation Brackets - $109.95
8/14/13 - Energy suspension Rear Swaybar Links - $21.99
8/14/13 - UMI Rear End SwayBar Install Kit - $79.99
8/14/13 - UMI Heavy Duty Billet Aluminum Rear Swaybar Mounts - $99.99
8/27/13 - Energy Suspension Rear Bump-Stops - $17.88
9/13/13 - UMI Front 1-3/8" Swaybar Bushing Set - $26.99
11/28/13 - Jegster Adjustable/Leveling Panhard Bar Bracket - $85.99
12/25/13 - UMI Chromoly Double-Adjustable Panhard Bar With Roto-Joints - $215.02
6/3/15 UMI Chromoly Double Adjustable Lower Control Arms With Roto-Joints - $308
Brakes ($881)
3/31/13 - EBC Redstuff Front Brake Pads - $88.99
8/18/13 - EBC Redstuff Rear Brake Pads - $66.34
8/13/13 - 1x Motul RBF 600 Brake Fluid - $14.17
9/12/13 - 3x Motul RBF 600 Brake Fluid - $53.97
10/8/15 - 4 Piston Front CTS-V Calipers - $246
10/8/15 - Kore3 CTS-V Caliper Swap Kit (Stainless Steel Brake Lines) - $86
10/8/15 - 14" ACDelco 5th Gen Camaro Front Rotors $159.56
10/8/15 - Castrol SRF Brake Fluid - $55.98
5/4/17 - Strano Master Cylinder Brace - $109.99
Wheels/Tires ($1,322.29)
11/12/13 - OEWheels C5 Replica Polished Front 17x9.5" & Rear 18x10.5" wheels - $591.00
12/17/13 - McGard Chrome SplineDrive Wheel Lug Installation Kit - $81.29
9/25/17 - 2x Michelin Pilot Super Sport 295/35/18 Rear Tires - $650
Exterior/Appearance ($1,388.15)
5/1/12 - Charcoal Metallic License Plate Firebird Overlay - $9.99
5/1/12 - "Trans Am" Air Dam Decal - $11.99
5/1/12 - "Pontiac" Headlight Decal - $6.99
5/1/12 - "Pontiac" Rear Bumper Inlay - $8.99
5/1/12 - "Trans Am" Door Overlay - $9.99
7/17/13 - Smoked Front & Rear Side Marker Lights - $53.95
8/21/13 - BitViper Shorty Antenna - $25
8/22/13 - GM Fixed Antenna Bracket (Power Antenna Replaced with BitViper shorty antenna) - $17.82
9/17/13 - Black Trans Am Brake Caliper Decals - $14.99
12/18/13 - 194 LED License Plate Bulb - $13.49
12/16/13 - Smoothlocks F-body Package - $20.00
3/13/15 - Sail Panel replaced with pre-98 panel - $500
3/13/15 - CETA Mod (Professionally painted (No cheap rattle-can or plastidip) rear lower bumper section in satin black, just like CETA's) - $150
3/13/15 - Antenna deleted from quarter panel and painted - $350.
4/21/16 - LED Foglight retrofit (Complete LED housing, not just an LED bulb in stock housing) - $69.95
?/??/15 - Windows Tinted. 20% on front windows and T-Tops, and 5% on the back glass. - $175
Interior ($417.71)
9/12/13 - GM Ashtray - $13.43
9/13/13 - GM TCS Traction Control Switch Panel - $34.95
9/17/13 - Trans Am/Camaro Auto Trix Passenger Window Fix Kit - $29.99
5/2/15 - Kee Audio Sail Panel DVC Speakers - $179.98
5/1/15 - Lloyd Trans Am Red Logo Front Floor Mats - $99.90
11/26/16 - Hurst Leather Shift ****- $59.46
Maintenance/Supporting Mods/Accessories ($706.97)
3/31/13 - Prothane Red Poly Motor and Trans Mounts - $74.99
6/04/13 - GM Low Side Port A/C Cap - $1.05
6/04/13 - GM High Side Port A/C Cap - $6.75
9/12/13 - GM Turn Signal/Hazard Flasher - $14.91
9/12/13 - GM RH DRL/Turn Signal Housing - $33.19
9/17/13 - GM LH DRL/Turn Signal Housing - $38.99
11/7/13 - Rodney Dickman Headlight Motor Rebuild Kit (Aluminum Headlight Gears) - $79
12/20/13 - Gates K040410 A/C Belt - $12.01
12/20/13 - Used Low Mileage AC Delco A/C Compressor - $115
1/19/14 - California Grey Stormweave Custom Fit Car Cover - $189.98
1/14/14 - GM Rear Main Seal - $17.86
1/14/14 - GM Rear Main Timing Cover Gasket - $19.61
5/26/15 - ACDelco Water Pump - $103.63
I have a full container with ALL stock parts to go along with the car, along with the stock wheels in mint condition! I am definitely missing alot of stuff in this list. The stuff listed above is the stuff that I remembered to put the receipts into my binder.
Speaking of binder, I have a 2" Binder that was passed down from the 1st owner, to the second, and then onto me. It has EVERY service and mod receipt for the car, including the original window sticker and purchase order for when the car was Factory ordered by the original owner from Sun Pontiac!
Lastly as full disclosure, the car has been in one very minor "accident", if you can even call it that. In October of 2015 I was on my way home with the car, when a drunk driver veered onto my lane and brushed my front left fender. My body shop wanted to repair it, but since Hagerty was footing the bill I had them replace the bumper and fender with Genuine GM replacements from the dealers. It was also a great excuse to respray the front and get rid of any rock chips (Front bumper looks amazing, and paint match is perfect). Please see the link below for pictures, and you'll see that it wasn't bad at all.
https://drive.google.com/open?id=0Bw...XBMSTRtQUJkbEk
Most of that was just rubber from the other car's tire that rubbed onto my fender. When I polished it out, the damage wasn't even noticable, but I fixed it because there was no reason not to (and I'm slightly OCD)
While it was in the body shop, I gave them money out of my pocket to replace the sail panel and delete the antenna from the quarter panel (Car looks so smooth and clean without the stock RC car look). Radio reception does suffer a bit, but I have an auxiliary input that I plug my phone into and use Pandora, idk what your preferences are but this setup worked great for me.
Please Email me at ChrisSingh90@gmail.com with any Questions/Comments/Concerns! Car has no lien, with a clean NYS title in-hand!
Chris
Attached Thumbnails 2002 Trans Am WS6 6-Speed 59k Miles-893218_225718910899736_77279783_o.jpg   2002 Trans Am WS6 6-Speed 59k Miles-26239242_10216115898556510_4595103507507357101_n.jpg   2002 Trans Am WS6 6-Speed 59k Miles-26991996_10216115898196501_152876100779691060_n.jpg   2002 Trans Am WS6 6-Speed 59k Miles-26804778_10216115898756515_3609039833211904612_n.jpg   2002 Trans Am WS6 6-Speed 59k Miles-26731102_10216115899596536_6411356123175650982_n.jpg
2002 Trans Am WS6 6-Speed 59k Miles-26804882_10216115899236527_2915087556021927250_n.jpg   2002 Trans Am WS6 6-Speed 59k Miles-26815114_10216115898916519_3679946600760599037_n.jpg   2002 Trans Am WS6 6-Speed 59k Miles-1233953_10203474203762041_291088212_n.jpg   2002 Trans Am WS6 6-Speed 59k Miles-1044595_10201680862369627_1213863931_n.jpg   2002 Trans Am WS6 6-Speed 59k Miles-20161102_215645.jpg
2002 Trans Am WS6 6-Speed 59k Miles-img_20180117_191439.jpg   2002 Trans Am WS6 6-Speed 59k Miles-img_20180117_191434.jpg   2002 Trans Am WS6 6-Speed 59k Miles-img_20180117_191525.jpg   2002 Trans Am WS6 6-Speed 59k Miles-fb_img_1516221433158.jpg   2002 Trans Am WS6 6-Speed 59k Miles-christhemadscientist_180118_005752.jpg
Old 01-19-2018, 09:52 AM
WS62000's Avatar
Beautiful!
Old 01-19-2018, 12:47 PM
LS1Fever99's Avatar
Probably one of the best F/S ads I think I've ever seen. If I was in the market, I'd be interested just because of the thoroughness. LOL.
Old 01-19-2018, 05:13 PM
gdawg's Avatar
PM sent
Old 01-20-2018, 04:10 PM
98 Raptor TA's Avatar
Only someone who's OCD like myself can truly appreciate the level of OCD that went into keeping this car pristine. lol. Good luck with the sale. I miss my TA. If you were closer I might have bought it just for the nostalgia.
Old 01-22-2018, 09:50 PM
A local came and looked at the car tonight, was sold right after the test drive. Can officially say it's going to a new home!
Bittersweet moment, thanks everyone for the kind words! I know I'm going to regret selling it sooner or later.
Chris
Old 01-23-2018, 07:04 AM
low_kal's Avatar
Shoot.
I thought it would go this way.
Good job with the sell man. This is Kyle by the way; I had been emailing you.
Guess I'll get back on the hunt. Lol.
Quick Reply: 2002 Trans Am WS6 6-Speed 59k Miles
