LED Gauge Cluster Lights
Old 01-12-2009, 04:33 PM
philsblwnz28's Avatar
Default LED Gauge Cluster Lights
I want to do my gauge cluster lights in LED. Where is everyone getting there LED lights at? I found a website called www.superbrightleds.com. I just don't know which lights to get. Thank you
Neto Muņoz (11-12-2022)
Old 01-12-2009, 04:54 PM
f-tothe-ill's Avatar
You'll need 5 of the 194 bulbs for the gauge cluster. I highly recommend getting the WLED-x5 over the regular ones, unless you want hot spots. If you want to swap out the lights in the door panels and HVAC also, they are 74 bulbs and you'll need four of them (2 for the doors, 2 for HVAC) and again I recommend getting the xHP over the regular ones.
Old 01-12-2009, 05:00 PM
BIG_MIKE2005's Avatar
Just PM Brian2006, he can point you in the right direction. Personally I'd never buy a LED kit for our interior from another place than the one he suggested to me. Very nice complete kit & the only bulbs you have to solder is the headlight switch & ASR/TCS. I love mine.
Old 01-12-2009, 05:05 PM
fbodyrs96's Avatar
93-96 camaro gauges takes 7 194 LEDs and I have no hot spots using these WLED-x-x LED bulb 120deg..use the NeoWedge Instrument LED bulb 3mm for the headlight switch plug and play..these work best in door handle trim 74-xHP Wedge Base LED Bulb, HVAC 74-x Wedge Base LED bulb and the shift plate auto 74-xHP3 Wedge Base LED bulb. I have all three 74's they sell and this was the best comb for the most unformed light.
Old 01-12-2009, 05:11 PM
98 WS6's Avatar
That's where I got mine from. I used WLEDx5 And they worked great. Much brighter red now
Old 01-12-2009, 08:58 PM
Well, just for ***** and giggles I went to pepboys and bought some led 194 bulbs and they won't even turn on in the cluster. I also bought some blue 194 bulbs, they also wouldn't turn on. So it that saying I need LED's with resistors built into them?
Old 01-12-2009, 09:15 PM
fbodyrs96's Avatar
super bright LEDs are built in and if they don't light up turn it around and try again..this is what I had to do to mine..
I had to pull the leads up and wrap them around the connectors..
Old 01-12-2009, 09:20 PM
Would I be safe to go ahead and order the WLEDx5 bulbs for the gauge cluster?
Old 01-12-2009, 09:27 PM
fbodyrs96's Avatar
these are the ones I used WLED-x-x LED bulb 120deg, there bright and unformed all over, so I guess it depends on how much you want to spend. I would take out the dash and count all of them, I order 5 and really need 7 so it up to you.
Old 01-12-2009, 09:29 PM
Could you get a pic of them?
Old 01-12-2009, 10:01 PM
Magnet's Avatar
so do you need 5 or 7 for the gauge cluster? and do you need 1 or 2 NeoWedge Instrument LED bulbs for the headlight switch?
here is my complete order so far by the way:
4 74-xHP Wedge Base LED Bulb Red 74-RHP $ 9.96
2 NeoWedge Instrument LED bulb Red NEOx-R 3mm NEO3-x $2.58
5 WLED-x5 LED Wide Angle LED bulb Red WLED-R5 $14.95
Subtotal: $ 27.49
Shipping: $ 5.00 (estimated)
Grand Total: $ 32.49
Old 01-13-2009, 12:07 AM
you need 5. two are for turn signals and it doesn't matter what color bulb you put in there they will still be green.
Old 01-13-2009, 12:23 AM
fbodyrs96's Avatar
the 93-96 camaro uses 7 and you only need one neo wedge and 4 #74 unless it's an auto than it takes a #74 to. by the way the 74-xHP Wedge Base LED Bulb sucks in the HVAC..
heres my gauges with 6 LEDS and I have still have white, it took 7 to make it all blue
Old 01-13-2009, 03:18 AM
Kingc8r's Avatar
LS1Tech 10 Year
I have heard LED lights tend to go out quickly. How long have you guys had them?
Old 01-13-2009, 06:18 AM
Thats only the cheap shitty LED's. LED lighting has a far longer lifetime than normal bulbs.
Old 01-13-2009, 08:30 AM
stealth355tpi's Avatar
LS1Tech 10 Year
i had to turn the brightness down on the camera to get a clear pic but here are the ones from superbright, the WLED-xHP. these are the white ones but show with a tint of blue.
Old 01-13-2009, 12:53 PM
Magnet's Avatar
Which white version are these? There are a couple different ones..
Old 01-13-2009, 02:15 PM
fbodyrs96's Avatar
7 blue WLED-x-x LED bulb 120deg
1 NEOx-R 3mm blue
HVAC 74-x Wedge Base LED bulb blue
Old 01-13-2009, 03:05 PM
nrs2420's Avatar
So they actually make a kit for this? I'll have to pm the guy.
Old 01-13-2009, 03:24 PM
ramairroughneck's Avatar
What color bulbs do you firebird owners use. Red or white? The Macewens really dimmed my cluster.
Quick Reply: LED Gauge Cluster Lights
