Flowing heads question
Old Feb 13, 2004 | 04:46 PM
foff667's Avatar
LS1TECH Sponsor
Default Flowing heads question
should ls1 heads fit on a standard flowbench jig for SBC & BBC? meaning a std 4.0 in bore?
Old Feb 13, 2004 | 04:50 PM
Cstraub's Avatar
SBF will work.
Chris
Old Feb 13, 2004 | 05:10 PM
foff667's Avatar
LS1TECH Sponsor
small block ford? really? damn gm is strange
Old Feb 13, 2004 | 05:46 PM
Cstraub's Avatar
Yes, most shops are using the SBF BHJ plate to hone cylinders instead of buying the new LS1. The LS1 heads bolt directly on a SBF block and if you turn the intake around it will line up with spacer plates to take up the deck height difference.
Chris
Old Feb 13, 2004 | 06:05 PM
foff667's Avatar
LS1TECH Sponsor
thanks chris
Old Feb 13, 2004 | 06:24 PM
mike m's Avatar
so im taking the ford is a 3.90 bore?
Old Feb 13, 2004 | 06:25 PM
foff667's Avatar
LS1TECH Sponsor
it appears to be 4.002 i think?
Old Feb 14, 2004 | 12:21 AM
Brian Tooley Racing's Avatar
Chris
The SBF has a bore spacing of 4.38", the LS1 has the same bore spacing as a SBC 4.40", so it will be off .020"-.040" from one hole to the next, if the head is centered, which will be hard since the dowels don't fit either.
And when we mocked up a SBF intake on it, it did not line up at all, no matter which way you turned it. The runners from the SBF to the LS1 run at completely different angles, the LS1 is more "compact" from end to end, the SBF is more "spread out" from end to end. See what I mean??
Old Feb 14, 2004 | 12:30 AM
They will sorta fit but not give accurate numbers. If you plan on running a set of heads on a 3.90" bore then flow it on a 3.90" bore.
For example
our Stg 2.5 6.0L/LS6 intake program on a LS6 head with the stock 3.90" bore chamber flows 325 @.600" on a 4.00" bore and 320 on a 3.90" bore- only a loss of 5cfm
The 6.0L head with the same exact everything flows 324 @ .600" on the 4.00" bore but only 309 @ .600" on the 3.90"- a loss of 15 cfm
so you can see if you flow a head with a chamber that is bigger then the bore you flow it on then it is very ditrimental to the flow, so you may not get the full answer if you port and flow LS1 heads on a 4.00" bore fixture. Hope this helps. Brian
Old Feb 14, 2004 | 07:30 AM
foff667's Avatar
LS1TECH Sponsor
Thanks Brian
