PRC Heads, Injectors, 4L60e, Springs, AC, Oil Pan, Catch Can, Lid, Plus more
Category: Accessories
Price: $0
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): NC
Item Condition: Used
LS Engine?: Fits LS Engine
Parts are all located in Fayetteville, NC 28306. Prices with shipping are to lower 48 only. All truck / LQ4 parts have 62k miles. Please ask questions before buying
1. PRC Stage 2.5 5.3 heads (59cc) - $700 shipped. I purchased these used from a member on here about 4 years ago and I put about 8k miles on them. I had a machine shop replace one of the valve guides after a bent valve on the dyno (Loose rocker) and all miles were put on after that. Does not include springs, only the heads and valves
http://www.texas-speed.com/p-1172-pr...ted-heads.aspx
2. 80lb Siemes Deka Injectors - $350 shipped. Sent to FIC for testing and flowing. http://fuelinjectorconnection.com/sh...hp?productid=9 SOLD
3. 30lbs Bosch Design III (36lb @ 58 PSI)- $150 shipped. http://fuelinjectorconnection.com/sh...p?productid=18
4. 98 Trans AM stock injectors - $60shipped 90k miles
5. 4l60e - $150 picked up. Will deliver within reason for gas$$. 90k miles, been sitting inside garage since 2009 full of fluid. No known problems at time of removal
6. 4l60e Stock Convertor - $80 shipped 90k miles, been sitting inside garage since 2009 full of fluid
7. 2004 Truck intake w/rails and injectors. $175 shipped.
8. 2004 Truck Throttle body - $75 shipped
9. ARP HEAD STUDS 234-4110 NEW - $250 shipped. SOLD
10. ARP Head Bolts 134-3609 - $125 shipped. 8k miles SOLD
11. Stock 98 Perimeter Heads w/valve covers - $175 shipped. Stock valves and springs included but not assembled
12. 98-02 F body BBK Long Tube Headers w/Y Pipe, chrome - $200 Shipped Minor surface rust. 8k miles SOLD
13. 98 Trans Am Exhaust manifolds - $100 shipped
14. 98 Trans Am Stock Y Pipe w/Cats - $150 shipped
15. 98 Trans Am Rotors - $50 shipped
16. 98 Trans Am RED flat hood ,paint in good condition - $100 picked up or you arrange shipping
17. 98-02 Black Camaro RS Ground Effects (Sides and Rear) - $275 picked up
18. 78mm FAST Throttle Body (No sensors)- $125 shipped SOLD
19. Texas Speed 7.375 pushrods – $100 shipped / 8kmiles SOLD
20. Comp Cams 7.325 pushrods - $100 shipped / 5 miles
21. Stock 7.4 pushrods - $15 Shipped
22. 98-02 F Body ProBox (2 10” Subs) - $50 picked up only
23. 98-02 F Body stock eFans and shroud - $150 shipped
24. Huron Speed Alternator relocation brackets - $100 Shipped
25. Mike Norris Catch Can (Red) - $125 Shipped SOLD
26. 98-02 Camaro LeBra (blk) - $50 shipped / $35 picked up
27. 98-02 F Body Air intake base (non ram air). $50 shipped
28. Comp Cams Springs (26918) 5k miles $100 shipped SOLD
29. 04 LQ4 Coil packs and bracket - $85 shipped SOLD
30. 98-02 F Body SLP Air Lid - $65 Shipped SOLD
31. 04 Truck Oil Pan - $50 Shipped
32. 04 Truck Oil pick up and Windage tray - $35 Shipped
33. 2010 Camaro (Inferno Orange) Rally Stripes - New - $125 shipped http://www.revolution-motorsports.co...ally%20kit.htm
34. 98-02 F Body Serpentine Belt Tensioner - $30 shipped SOLD
35 98-02 F Body Fast Toys Ram Air - $115 shipped
36 LQ4 Windage Tray and Pick Up Tube - $45 shipped
37. 98 F Body MAF - $50
38. F Body AC Compressor w/ accumulator and bracker - $125 Shipped (Less than 1k miles on it )(Delphi 1311)
39 F Body Condensor - $50 shipped
Also have a 98 LS1 block, outer starter mount hole broke off, been using a nut on the end of a bolt for 3 years, no problem. #8 needs to be re-ringed getting a lot of blow by.
Pics are big so you can see detail. Parts have not been cleaned yet, will cleanup before shipping. More to follow
