Pro Systems Pro Series 4150 Carburetor 830CFM
Category: Engine - Intake/Fuel
Price: $625
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): NY
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
Selling my Pro Systems 4150 style 830CFM No Choke/Mechanical Secondary carb. This carb has been good to me, i've had it on the car for about a year but taking a different direction with the car. This is an extremely high quality carb one of the best manufacturers out there IMO, picked up some big power with this carb.
All the specs on the carb are included in the pictures on the build sheet. It's a true 830CFM Carb. The only thing i switched out were the idle air bleeds which now sit at 0.90's.
Included with the carb is both the build sheet and bill of sale, which gives you access to the Pro Systems 24 hour tech line. I will also switch registration under your name once you have the carb.
I'll also include my wood half inch carb spacer which helps keep it cool, some needles and seats, and other random carb related items i have laying around FREE.
The price i'm asking is $625 shipped, i feel this is a good price for the carb i paid $738 for about a year ago. As you can see it's still in brand new
condition.
http://www.prosystemsracing.com/index1.html
Any questions, concerns, or wanting more pictures just let me know!:thanks:
You can also call or text me at my cell # 718-578-7184 Bryan
The engine i had him spec this carb out for are is.
Vehicle Weight: 3350
Engine Brand: Chevy
Engine Cubic Inches: 383
Compression Ratio: 10.4-1
Intake Manifold Brand: Edelbrock Air Gap 7501
Intake Manifold Bolt Pattern: Single 4150
Cylinder Head Type: Patriot Performance Freedom Aluminum heads
Engine HP (or estimate): 450hp
Launch RPM: varies
Track Length: Other
Fuel Type: Gasoline
Fuel Pump: Mechanical
Fuel Pump GPH Rating: 150gph
Transmission Type: Manual
Suspension Type: Factory Suspension
Cylinder Heads Ported (if heads have been flowed, include flow #'s in space provided): No
Mufflers: Yes
Type of Camshaft: Hyrdaulic Roller Lifters
Camshaft - Intake Duration @.050: 247
Camshaft - Exhaust Duration @.050: 253
Camshaft - Intake Lift at Valve: 0.565 in.
Camshaft - Exhaust Lift at Valve: 0.580 in.
Lobe Separation: 110
Header Diameter (List size for stepped header in space provided.): 1 3/4"
Engine Brand: Chevy
Launch RPM: varies
Track Length: Other
Fuel Type: Gasoline
Mufflers: Yes
