YELLA TERRA Ultra Lite 1.7 Rocker arms Adjustable
Category: Engine - Intake/Fuel
Price: $430
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): PA
Item Condition: Used
LS Engine?: Fits LS Engine
Perfect condition Yella Terra 1.7 rockers arms for ls1,2,6 family of engines, direct bolt on replacement, stock 1.7 ratio, in perfect shape. Fully adjustable for use with hydraulic or solid roller. You can set your lifter preload with out dealing with differnt length push rods!
SOLD
YELLA TERRA YT6638
GM LS1 ULTRALITE ROCKER ARM KIT- 1.7 RATIO- ADJUSTABLE
Intake and exhaust rocker arms are joined in pairs on a shaft that is 22% larger and engineered for extreme RPM. Compatible with stock and most aftermarket cylinder heads, rocker arms bolt to existing 7/16" stud mountings with bolts supplied. Sets of 16 with hardware.
Designed for the most severe race applications Platinum rockers feature wide body arms for even greater strength and resistance to deflection.
All platinum rockers feature heavy-duty 7/16 mountings for unsurpassed rocker stability.
Platinum rockers are available in twin shaft versions for parallel valve applications and unique single shaft designs for cant valve small block and big block engines.
The range covers most popular factory and aftermarket performance heads in a choice of ratios.
PART NO YT 6638
ENGINE 5.7L LS1 V8
YEAR 06/99|07/06
PART TYPE ROLLER ROCKERS
MOUNTING STYLE Shaft Mount
ROCKER ARM RATIO 1.7
STUD SIZE 8mm
ADJUSTABLE ADJUSTABLE
HYDRAULIC -
ROCKER ARM STYLE FULL ROLLER
SHIMS INCLUDED Yes
ROCKER MATERIAL ALUMINIUM
SELF-ALIGNING NO
ROCKER ARM BODY STYLE STANDARD
ROCKER ARM NUT STYLE Capscrew
MAX SPRING DIAMETER 1.550"
INLET OFFSET -
QTY SET OF 16
YT6638. Yes stealth ultra lite adjustable rockers. That use the stock size 8mm rocker bolt
YELLA TERRA YT6638
Bolt on shaft type adjustable 1.7:1 use with YT5123 v/cover spacers
PART NO YT 6638
ENGINE 5.7L LS1 V8
YEAR 06/99|07/06
STUD SIZE 8mm
HYDRAULIC -
SHIMS INCLUDED Yes
SELF-ALIGNING NO
INLET OFFSET -
QTY SET OF 16
YELLA TERRA YT6638
PART NO YT 6638
ENGINE 5.7L LS1 V8
YEAR 06/99|07/06
STUD SIZE 8mm
HYDRAULIC -
SHIMS INCLUDED Yes
SELF-ALIGNING NO
INLET OFFSET -
QTY SET OF 16
