Are dash pads interchangeable?
Old 04-25-2017, 06:14 PM
aaahicks1's Avatar
Default Are dash pads interchangeable?
Hey guys. Are dash pads for Fbodys interchangeable? I have a 1996 Formula, I found a pad from a 2001 Camaro SS. Are they different?
​​​​​​​Thanks in advance guys.
Old 04-25-2017, 10:04 PM
shbox's Avatar
Are you referring to the panel under the windshield that usually is cracked? If so, AFAIK, 93-96 Firebirds are the only ones the same (from what old part numbers bear out).
Old 04-26-2017, 12:50 AM
ElkySS's Avatar
I believe the only difference is the shape of the defroster vent. It should still remain functional when swapped. not 100% sure tho.
Old 04-26-2017, 04:39 AM
aaahicks1's Avatar
Yes SHBox, that is the part I'm referring to. Thanks.
Quick Reply: Are dash pads interchangeable?
