i think this is my noise
may be hard to tell but its wobbling. dont know if thats normal or not
the sound doesnt really come from the engine, its quiet from the top but get under it its much louder.
from inside, when i put in reverse i cant hear the noise anymore. would that point to anything to check?
any way to know for sure if thats it before replacing?
any other possibilities?
whatever the noise is it wasnt there before. maybe its nothing serious but knowing my luck its a spun bearing.
today i took off the serpentine belt and ac belt, and ran it. it still made the noise. i went ahead and greased all the bearings in the pullies and tensioners.
so what possibilities am i looking at here? anything besides a spun bearing? any way to confirm or rule that out?
it doesnt sound like the videos online of a spun bearing, but maybe ive just caught it early and its not as bad as the videos?
If you still have good oil pressure and no metal in the oil you likely have no bearing issues. It sounds lifter'ish. Lifters are common to have collapse on these and fortunately not terribly expensive. They are a little labor intensive though. Give us a call if we can help you further diagnose it or get any parts for you.
Thank you,
Kyle
972-853-2450
Thompson Motorsports
BTW, The balancer will not make the noise unless it is hitting something, I don't see it hitting anything so I would look elsewhere.
Thank you,
Kyle
972-853-2450
Thank you,
Kyle
972-853-2450
Thank you,
Kyle
972-853-2450
First piece of help I can give you: Don't resurrect 7 ( or 4 or 5 or 20 ) year old threads, as A) Most times the OP is long gone B) The problem has likely long since been solved and C) It annoys long timers. People post up problems on the regular, and it's best to just go to recent posts in each section and reply to anything you feel you have input for. Not trying to be a jerk, it just makes the site run smoother.
