BMR anti-roll bar install Q's!
Old Jun 22, 2017 | 01:25 PM
00-SS12's Avatar
Default BMR anti-roll bar install Q's!
I recently installed a moser 9" on my fbody & while I was doing so figured I would put a new rear sway bar on so I ordered the BMR extreme Anti-roll kit. Really nice product and the install wasn't bad but i have one question about it, my bar sits pointed downward a bit & in the instructions it says to have it level with the ground but end links don't get short enough to have it level with the ground, even using the upper mounting point on the bracket... I am lowered on eibach pro kit springs, thinking the ride height has a lot to do with it but the kit says it works with lowered cars.. any input!!?
Old Jun 22, 2017 | 03:16 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
That is no problem. I see this a lot with lowered cars. It won't have any negative effect on the functionality of the bar. Having it level is more for ground clearance than anything honestly. Looks like a lot of red going on under there. Looks good!
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Jun 27, 2017 | 06:27 PM
00-SS12's Avatar
awesome sounds good thanks for your reply! Lol i would of done black rearend but bought the moser 9" used from someone local here and it came all red so i cant complain I guess!
Old Jun 27, 2017 | 09:09 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
What's the ground clearance with those pipes ?
Old Jun 28, 2017 | 06:43 PM
00-SS12's Avatar
it's ridiculously low clearence.. true dual rear exit kit made by speed engineering.. I'm sure on a factory ride height it woulnt be bad but the kit was $500 (+panhard relocation) so for the price I'm not super disappointed.. At the end of the x-pipe the pipes slightly drop down so gonna take it to an exhaust shop and have them redo it to tuck it up some
Old Jun 13, 2026 | 09:54 PM
Busaboy's Avatar
Thanks I plan own buying one I'm glad you have a true dual setup..
[/QUOTE]
Old Today | 05:50 AM
Rick Dorion's Avatar
I had the same question and the same answer when I put a Ridetech rear sway bar on my Bel Air. I called them and they said it was normal on my 2" lowered car.
