Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Vengeance Racing Store - Many Used Items - Some New!
Old 09-13-2017, 03:13 PM
LS1TECH Sponsor
Vengeance Racing's Avatar
Default Vengeance Racing Store - Many Used Items - Some New!
Category: Accessories
Price: $11111
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): GA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
We accept offers through EBay! Please click the links below for more information...SEVERAL PAGES...CHECK THEM ALL!!!
PAGE 1 -- 4th Gen F-Body or 5th & 6th Gen Camaro Specific
6TH Gen Camaro
LT1 (Gen 5) High Pressure Fuel Pump 12669519
5th Gen Camaro
K&N 63-3074 CAI For 5th Gen Camaro SS
Gen 5 Camaro Exhaust Manifolds and CATs (with O2 Sensors)
Camaro SS (5th Gen) Stock Fuel Bucket - 13575886
Hawk HPS Brake Pads - HB453F.585
Steering Bracket Idler for 5th Gen Camaro - 12542401
Camaro ZL1 Fog Lamps - 10335108
4th Gen F-Body
4th Gen FBody Factory Upper Air Box
Attached Thumbnails Vengeance Racing Store - Many Used Items - Some New!-vr.png
LS1TECH Sponsor
PAGE 2 -- C5, C6, C7 Corvette Specific
C7 Corvette
C7 Corvette 8L90E Transmission With Circle D Converter
C7 Corvette Stingray Brake Rotors
LT4 Corvette Supercharger Lid
C7 Corvette Z06 or Z51 Rear Spoiler - Blade - Black
C7 Factory Torque Converter
C7 Z06 Corvette Factory Balancer - LT4 - 12662047
C7 Procharger Race Intercooler
C7 Z06 18% Overdrive Pulley
LT1 Style (Gen 5) Throttle Body Housing - Polished
LT1 (Gen 5) Valve Covers (wet sump)
C6 Corvette
LS7 Innovators West 6-Rib Harmonic Balancer - Standard Diameter
C6 Corvette PFADT Solid Engine Mounts
C6 Or C5 Corvette Z06 front Sway Bar - 30mm - 10419094
C6 Z06 Torque Tube - (2005-2006)
C6 Corvette Shock Absorbers (used)
C6 Wide Body Bogart Racing Wheels (15 x 10 Bead Locks)
C6 Or C5 Front Leaf Spring - 15233397 - FE1 (Soft Ride)
C6 Rear Leaf Spring - 15233388 - FE1 (Soft Ride)
C6 Differential - 2.56 Gear Without Cooling System - 24235244
C6 Passenger Side Air Bag
C6 XM Radio Antenna
C5 Corvette
C5 Z06 Differential 3.42 Ratio - 12572683
C5 Corvette Factory Rear Window (Fixed Roof)
C5 Corvette Rear Spindles/Hubs Modified For Strange Race Brakes
C5 Corvette ABS Bracket
C5 Corvette Front Wheel Houses (wheel wells)
C5 Corvette Rear Upper Control Arms
C5 Corvette Rear Lower Control Arms
C5 Corvette Rear Wheel Hubs - 30-Spline
C5 Or C6 Corvette Z06 front Sway Bar - 30mm - 10419094
C5 Corvette Rear Subframe Cross Member - 10266823
C5 Corvette Front K-Member Subframe - 10319530
C5 Corvette Front K-Member - 10312076
C5 Rear Brake Calipers for 15-Inch Conversion
C5 Z06 Seats With Brackets - Mod Red
C5 Corvette Alternator (painted Black) - 10316182
C5 Corvette HVAC Box (Under Dash)
C5 Corvette Dewitts Pro Series Radiator for 2001-2004 C5 Corvettes (1139101A)
C5 Wiper Control Stalk Switch - 260047377
C5 Turn Signal Stalk Switch - 26075870
C5 Passenger Side Air Bag - 2002 Model
C5 A&A Corvette Secondary Belt Drive (single Bracket And Belt Only)
C5 Driver's Side Quarter Panel - Arctic White
C5 Fuel Door - Arctic White
C5 Radiator (manual Trans)
Old 02-15-2018, 03:43 PM
LS1TECH Sponsor
PAGE 3 -- CTSV, GTO, G8, or SS Specific
Chevy SS Exhaust Manifolds And Cats (2016 LS3)
CTSV Gen 2 Air Conditioning Parts (Coupe)
CTSV Gen 2 Horns with Bracket
CTSV Gen 2 A/C Condenser
CTSV Gen 2 Differential - A6 - 3.23 (Needs Axle Seals)
CTSV Gen 3 ARH Non-Catted connection Pipes
Old 03-02-2018, 11:22 AM
LS1TECH Sponsor
PAGE 4 -- LS Drivetrain (Gen 3 & Gen 4) or LT Drivetrain (Gen 5) Parts
Induction
LS3 (GM) Fuel Rails
LT1 Style (Gen 5) Throttle Body Housing – Polished
LS7 Intake Manifold with Carbon Fiber Hydro Dip
Truck (Gen 4) Throttle Body 2008-2009 Trucks
Mass Airflow Sensor for LS Engines - 5-Wire
Engine Acc.
LSx Solid Roller Camshaft (260/272 .754/.751 115LSA) - Some Damage
LSx Solid Roller Camshaft (256/268 .748/.748 115LSA) - Some Damage
ARE LS7 Style Dry Sump Pan With 2-Stage Scavenge Pump
LS7 (Gen 4) Intake Manifold - 12569011
LT1 Camaro (Gen 5) Valve Covers
PAC-1324 Valve Springs
ISKY Red Zone Solid Roller Lifters - 375RHM
LS (Gen 3 or Gen 4) Valve Covers
GM LS7 Damper - Balancer (Factory Unit) - 12575716
Morel LS Tie Bar Lifters - 5850 - Limited Travel
LT4 (Gen 5) GM Valve Covers (Wet Sump)
Wiseco Wrist Pins for LS Engines
Cometic LS7 Head Gasket - C5889-070
Comp Cams 7985 Chrome Moly Pushrods 8.050" 3/8" .080
CM Pushrods 7.225" 5/16" .080
CM Pushrods 7.850” 5/16” .080
Cometic MLS Head Gasket (Left Side)
Durabond CH-23 Cam Bearings
Injectors
None for sale at this time
Drivetrain
Pro Torque Converter TH400
Mantic 9000 Series Flywheel - F9001H
Old 03-19-2018, 07:22 AM
LS1TECH Sponsor
PAGE 5 --General LS/LT or Miscellaneous Parts (universal - not model specific)
Pirelli P-Zero Tires - Trofeo R - 305/30ZR20 (PAIR)
Strange Engineering Brake Rotor - B2794
US Gear Ford 9-Inch Ring And Pinion - 3.00 Ratio
Magnuson 10-Rib 3.200 Diameter Supercharger Pulley
Magnuson 96mm Supercharger Pulley (57-03-06-096-BL)
A&A Corvette 8-Rib, Cross Cut Supercharger Pulley - 3.00 Diameter
A&A Corvette 8-Rib Supercharger Pulley - 4.0 Diameter
Bill Miller Forged Aluminum Connecting Rods
DCM Axial Electric Puller Fan - 860026
AFE Air Filter Element - 24-90080
Gates K080889HD Belt - Green Stripe
Gates K080855 Belt - 8PK2173
Holley 860015 102mm Sniper Throttle Body Spacer
ISKY 9968-RAD Tool Room Valve Springs
AFE Filter R24-90088 Magnumflow
Napa 1-4866 Power Steering Cooler
Old 10-03-2018, 05:35 PM
David@Vengeance's Avatar
mid week bump
Old 10-29-2018, 07:41 AM
LS1TECH Sponsor
Bump for a new week
Quick Reply: Vengeance Racing Store - Many Used Items - Some New!
