Bought some spacers...lug nuts stick out past spacer??
Old 10-14-2017, 08:44 PM
quiet_storm98's Avatar
Default Bought some spacers...lug nuts stick out past spacer??
So i went ahead and bought some 20mm hubcentric spacers off of ebay. Had to cut my wheel studs down of course for them to fit and i ended up putting one on and noticed the open end lugnuts provided with them stick out slightly past the spacer. I went ahead and put my wheel on and it doesn't sit flush with the spacer because the provided lug nuts are somehow to long even though the are short style acorn lugs. So looks like only way to solve this is with a larger spacer so the lugs would sink into it or if somehow there are shorter lugs i could use. Don't really want to run a larger spacer because this one makes my 305's sit abput flush with the fender. Anyway below are some pics.
Old 10-15-2017, 06:22 PM
dojob's Avatar
most wheels have voids there
best thing to do is press out your wheel studs and the studs in the spacers. Then put new arp studs in. I have the same done with my setup
For stud/spacer reference I use:
-20mm (.78") hub centric spacers
-2.5" 12x1.5 .509 knurl ARP wheels studs
-1.38" 12x1.5 Rocket Racing lug nuts
This setup get you the the stock engagement for the lugs to thread onto studs
Old 10-16-2017, 03:52 AM
thanks for the info on the studs eventually i may swap to the arp's. As for lugs i found some shorter ones on ebay that should work
Old 10-17-2017, 01:15 PM
LS6427's Avatar
Man, I cannot find the 1.38" 12x1.5 Rocket Racing lug nuts anywhere.....Rocket Racing never replies to emails or calls.
Are they sold anywhere else...? Maybe ebay under a different name.....?
I'm pretty certain 20mm spacers will be what I need. Are those lug nuts closed ended....chrome plated?
Old 10-17-2017, 01:51 PM
dojob's Avatar
Take your pick
https://www.summitracing.com/search/...s%20Lug%20Nuts
Old 10-17-2017, 03:52 PM
LS6427's Avatar
Jeez....I never checked Summit....LOL
Thanks....
Old 10-17-2017, 05:59 PM
dojob's Avatar
happy to help
buy the singles, they're cheaper
Old 10-18-2017, 02:32 PM
LS6427's Avatar
happy to help
Yea....buying singles is best, I have 4 locking lugs that almost match them. So I only need 16.
Thanks...
Old 10-21-2017, 11:40 AM
Dojob did you have to cut down the arp studs in order for them to clear your wheels or did your wheels have a void for the studs to be able to stick out a lil? Just asking cuz my wheels don't have a void.
Old 10-21-2017, 07:15 PM
dojob's Avatar
I am using the arp studs to hold the wheel on along with the spacers. There is nothing holding the spacers on, except the wheel.
I pressed the spacers' studs out. Pressed the OEM studs out of the car. Then installed the 2.5" arp studs. Slid the spacers on. Put the wheels on. Tightened the lug nuts on. DONE
Old 10-21-2017, 07:36 PM
y2keglide's Avatar
Thanks...
I bought the kit from Rocket that had locking nuts with it, they (the lockers) were crap and stripped out long before getting to proper torque. I boxed them up and sent them back with a note just this Thursday,will be interesting to see what becomes of that. In the meantime I used 4 of my old lugnuts in their place.
Old 10-21-2017, 07:43 PM
y2keglide's Avatar
I had pretty much the same question and dojob gave me the same answer.
I did this exact swap and mounted 315/30ZR18's on the back.
Old 10-22-2017, 04:12 AM
hmmm interesting never thought of that...how hard is it to press the oem studs out and install the arps? I may go this route
Old 10-22-2017, 07:29 AM
fastlt1's Avatar
Why not pull spacer off. Put lug nuts on and grind some off of lugnut
Old 10-22-2017, 11:18 AM
dojob's Avatar
easy. just get a ball joint tool from harbor freight to press them out. then get a stud installer from summit.
should be like ~2hrs taking your time. pulling tires/brakes taking your time
https://www.harborfreight.com/3-4-qu...tor-99849.html
https://www.summitracing.com/parts/lil-22800
Old 10-22-2017, 11:34 AM
topless2002SS's Avatar
nothing like placing all the rotational force on the outside end of the stud, this should be worth another wheel off thread soon.
Old 10-23-2017, 06:46 AM
dojob's Avatar
Old 11-06-2017, 06:16 PM
01WS6BLACKLS1's Avatar
Hey not to highjack the thread. I have a question about those rocket racing wheels lug nuts. Would C1707H, the bag of 20, be the ones to use in place of the factory open ended lug nuts and plastic covers. They look like they would be a nice replacement for the price. They are factory 2001 trans am wheels. Thanks guys.
Old 11-07-2017, 06:51 AM
dojob's Avatar
correct. use those.
don't buy the bag of 20 for $25. but the singles for $1/ea.
Old 11-07-2017, 09:22 PM
Cool. Thanks again.
Quick Reply: Bought some spacers...lug nuts stick out past spacer??
