Turbo bracing question
I am putting twin s366 on 6.0 in a 92 Sierra regular cab. It has motor mounts and I am trying to figure out how I need to brace the turbos if I even need to at all. Don't really want to go to a motor plate but the mounts I'm running allow the motor to move some and I don't see how I can brace them unless it's to the actual motor.
If you wanna brace them to the frame you will.have to run a flex joint in the outside pipe between the manifold and the turbo. That is my plan anyway. My turbos will brace to the frame rail and it will have a flex joint in the outside piping to keep from breaking the outside pipes from torque over.
If the turbo is bolted to the engine, it will try to move with the engine. So make sure any brace you create will also move with the engine at both ends, in the same direction. Otherwise, a non-solid (non-clamped) mount should be used, one which allows rotation, flexible enough to account for all possible movements also in x and y directions, which to me sounds more difficult atm. Further, I feel that Flex sections in exhaust are limited in their ability to compensate for twist or bending, and any relief from such forces should be taken care of in the bracing. Any exhaust tube could be made to be "brace like" in addition to it's gas carrying ability, so do not neglect to think of a way in which to use the exhaust tube itself as part of a brace system.
