upgrading coils vs factory LS3 coils. any HP gains?
so upgrading to a SOS or holley coil pack, does this add any HP or anything to make the engine run better? or is it just a "check me out" upgrade?
In a really wide handwave, stock coils pretty much are fine up to about 12:1 static, at that point you may need to start raising the current to get good ignition in the cylinder. (Plug heat selection matters) Once you get up around 15:1 static, your in to the very high current-voltage ratio and it gets fancy, or you go magneto.
Fiddling with a midget motor a couple years back that had old school points, coil distributor, when we went full upgrade on the motor (Cosworth BDA) and set it up for 100% methanol, we had to convert to a magneto to start it.. it was running at almost 17:1 at that point, at TDC it was down to like 12CC's of chamber with tall pistons. 240 lbs of compression if I recall.. 1.8 liter making over 300hp at up to 10,000 rpm... Normally aspirated with twin injector Hillborne injection,, its sang when it went by...
Holley Smart Coil = IGN-1A
Hi ALL, the Holley Smart coil (IGN-1A) is good for about 18 HP on a 500 HP engine. (bench)
I DO NOT "HIP" SHOOT as did the above posters.
My DATA is PROVEN by dyno reports, EMPIRICAL, NOT GUESSES by THOSE WHO have NEVER done a BACK/BACK test.
There are users here at LS-1 Tech of my LS-IGN-1A kit.
THEIR reports are as follows :
Better throttle response
Less Spark Advance required
Better Fuel mileage
More power "felt" through engine operational range.
More power recorded when tested on a rolling road dyno.
So I ask : Would you TRUST a person who has fitted the Holley Smart coil/IGN-1A OR a person who has NOT ?
Lance
Better Fuel mileage
Lance
Last 1 (10-15-2023)
Better Fuel mileage
Lance
Better Fuel mileage
Lance
Better Fuel mileage
Lance
Better Fuel mileage
Lance
Lance are you talking about just the Holley or your 99891.510 LS coil for later models when doing comparisons?
I wouldn't be able to keep these coils in stock if I could prove an honest 18hp gain per 500hp. I find it hard to believe that anyone would run any other LS coil at a heads up race if they could pick up 4% power by swapping to IGN1a.
I see Lance posting a lot on here regarding how well these coils work. I want to see if they live up to what they are claimed to be. If they will net gains of 18hp on a 500hp, I have many customers that would be lined up to buy a set.
I’m glad I bumped into this thread. I have been talking to Lance about getting a set of his coils.
Lance Nist, of PanteraEFI, a sponsor/vendor here who has been in the performance world for decades, and has extensive knowledge of various automotive systems. He is from New Zealand, and sometimes his lines of thought runs in directions some here have a tricky time fathoming. He seems like a great guy though.
I guess also what type of LS coil are were talking LS1 coil or the LS7 coil as a base test for the 18 hp gain.
