Factory Y-Pipe
Factory Y-Pipe
Looking for a aftermarket y-pipe to connect after my factory cats? Can I use an ORY then cut it down and have it welded? I have an exhaust leak so this isn’t really for power gains and can’t run LT’s in CA.
LS1Tech Administrator
Received 1,795 Likes
SLP sells (or, at least they used to sell - not sure if they still do) a bolt-in replacement Y-pipe that connects to the factory cats. Cutting/welding would be required for a '98-'99 car, '00+ is direct bolt-in.
In CA you have to becareful, the cats have to be within a certain region (like no less than 2 inches of difference north or south) of the stock cats or it will fail visual emissions even if you have them. You're better off getting a Catted Y-Pipe
The SLP Y-pipe I mentioned above attaches to the factory cats, so it would not relocate them at all. There would be no reason to get a catted Y-pipe for this application if all you need is the piping after the cats.
