918853 and 8 rib setup
Old 09-10-2018, 05:19 PM
Chuck Brigham's Avatar
Default 918853 and 8 rib setup
Hey Guys, I just got my ATI 918853 balancer in and I'm a bit confused with the bolts they provided. Blue holes have threads and the red do not. I've attached the bolts provided as well. If I use the long bolt it would have to go though the 8rib into the holes with no threads and down to the AC pulley. If i use the shorter bolts in the threaded holes they bottom out on the AC pulley..... Any advice here would be helpful. I also bought the 8rib setup used so I'm not sure if there were instructions with that or bolts that might make more sense.
Old 09-10-2018, 05:32 PM
qweedqwag's Avatar
http://www.atiracing.com/instructions/Super-Damper.pdf
Old 04-21-2019, 01:56 PM
89mulletbird's Avatar
Chuck did you figure this out? I have the same problem today.
Old 04-22-2019, 05:48 AM
forcd ind's Avatar
I'll send this to my buddy at ATI, their close by, since 2 of you are having the same problem.
