Can someone help me with compression ratio?
Can anyone help me out with how much to shave LS3 (821) heads on a flat top 370ci 6.0L? Cam is Cam Motion 220/234 114 .610"/.615" with LS9 head gaskets, an LS3 intake and not sure on springs yet.
Before I knew any better I had told the shop to cut them .005" to clean em up. Well, they did it and now I realized I probably should have gone deeper? They charged $150 for the first shave and it will be another $150 if I want to cut them more.
Street 87 C10 short bed. Occasional daily drive and weekend toy really.
Cam Motion told me .030 would put me at 11:1 and if I go .020 that would put it at 10.9:1 but at the .005 I am at now I'd venture a guess that I am only at around 10.6 or 10.7:1
Is this going to be decent on pump gas for what I want?
A 4.030 bore with 3.622 stroke and 68cc heads, flat tops and assuming a zero deck with a .051 head gasket yields 10.6:1 with dynamic compression roughly 9.5:1 so you will be just fine on pump gas.
Measure how much the pistons are in or out of the hole before buying the gaskets if you want to dial it in. If you are just wanting to know if it will be good on pump gas then like 01CamaroSSTx said, you'll be fine. Here you go:
https://drive.google.com/file/d/1MDT...CcBIIrpiv/view
These would work good. .045 thick, for use up to 4.070 which will work for your 4.030 bore and 4.065 heads. They also give you a little better quench coming in at approx .039 vs .046 with stock gaskets.
http://www.ws6project.com/user_stor/...oducts_id=6485
They are $70 too and MLS
I'm not sure what CC you're at with .005 shaved off but I used 68 cc in the calculator and got 10.94 with the above gaskets. At 69 cc you'd be at 10.81
With stock .052 gaskets (run LS3 gaskets) you'd be at 10.63 with 69 cc heads and with 68 cc you'd be at 10.75
Any of those ratios is pretty good. I personally would like to have around 11:1 to 11.5:1
All ratios are with using .006 piston out of the hole.
I punched in a few numbers and one of the things I noticed is the quench calc is backwards or the piston in the hole. You put on there a negative number means piston in the hole, that should be out of the hole
I put in a .052 gasket with piston coming out .007 and it's telling me that's .059 quench. It should say .045
If you change the piston compression distance such that it shows "+0.007" in row 12 that means it's coming out of the hole 0.007. If that's what it shows in the cell and you are using a 0.052 gasket it should calculate the quench as being 0.045.
https://ls1tech.com/forums/generatio...te-quench.html
The formula for quench is compressed gasket thickness minus piston out of the hole.
Yes thank you I understood how to calculate quench when I understood second grade math. I don't know how tall you are but my post went far over your head.
Try re reading it.
Your tool auto populates piston out of the hole. Then it auto populates quench. And it is populating wrong.
YOUR TOOL NEEDS TO BE CORRECTED. I DON"T NEED SCHOOLING.
Read the part in red a couple of times.
Try re reading it.
Try re reading it.
https://drive.google.com/file/d/1gmUWLXWxISqxcCgfYaVuZSWShXtJs4I-/view
My bad I was trying to look at it on my phone. Thanks again for finding this error. I made some corrections. New link here:
Received 1,836 Likes
Originally Posted by JimMueller
How did you calculate DCR without knowing advertised IVC?
