1995 Camaro ls1/4l60e swap 23k miles
For Sale1995 Chevrolet Camaro
Price
$5,900• OBO
- Location Phoenix, AZ, 85234, USA
- Condition Used
- VIN 2G1FP22S4S2106171
- Mileage 23,000
- Engine 8 cyl
- Drive Type 2WD
- Transmission Automatic
- Exterior Color Red
This is a 1995 V6 Camaro with a ls1/4l60e swap. The body has 130k miles while the motor/transmission have 23k miles. I purchased a wrecked 2002 SS Camaro and basically transplanted everything into my 95 including the motor/transmission, brake system, interior, wire harnesses, etc. The SS had 19k miles on it when I did the swap. I've put about 4k miles on her since I did the swap. Motor runs strong transmission shifts smooth.
Clear title.
Always garaged.
Open to reasonable offers. No trades cash only.
Engine/Drivetrain
Ls1 engine/4l60e transmission swapped from 2002 SS Camaro - 23k miles on motor/transmission
Yank SS4000 - 4k miles on convertor
PST Aluminum Driveshaft
Moser 9 inch rear no ABS/TCS spool with 3.50 gears 35 spline - 4k miles on rear
Ls6 intake
Dynatech 1¾ inch long tubes with catted y-pipe dumped into a bullet muffler
B&M External transmission cooler
TCI Deep Pan
Mail order tune
Removed AIR and EGR Emissions systems
All aftermarket mods have about 4k miles on them
Suspension
Wolfe Racecraft Rear sway bar
Wolfe Racecraft Torque Arm
Spohn Adjustable Rear Control Arms
Spohn Adjustable Panhard rod
BMR subframe Connectors
Spohn K-member
Sam Strano front sway bar
QA1 shocks all around 12 way adjustable
Tires have less then 5k miles on them
Plasti dip wheels black
Interior
Entire interior was swapped from the 2002 SS Camaro and is in excellent condition.
Driver air bag removed
Cruise control removed
AC removed
Rear carpet removed
"The Bad"
- P0757 code (shift solenoid) comes on/off intermittently. I believe this is an erroneous code that needs to be deleted due to the high stall convertor.
- Small crack in windshield
- Clear coat peel
- Does not pass emissions due to removal of AIR/EGR systems
Please PM Andrew for phone number.
