boltinga NV3500 to a 6.2 LS engine
i am putting a LS 6.2 engine into a 93 c1500 chevy truck. I am wanting to know if I can bolt the NV3500 up to the 6.2 without any mods.
I bolted the NV3500 from S10 to LM7 5.3 without problems. One thing, the bolt pattern on the bellhousing is not the same. I used only 6 bolts from the 8 on engine but that is not a problem.
did you ever get around to completing this, if so what clutch kit and pulley bearing did you use if you don’t mind. I haven’t found much support just yet on the input shaft to crank fitment
I think the input shaft is the same pilot and spline as your old school trans. The pilot bearing changed to a bearing "like" goes in the front wheel on wheel barrow. I can take some measurements or pics if you need I got one out of a 05 Silverado that I'm rebuilding engine that is 4.3. It's got a hydraulic throw out bearing that looks like the late 90s early 2000s ford rangers. From what I've read they are a nightmare to rebuild and not really durable with much power. It was about the easiest 4x4 transmission I ever pulled.
