Where can i find higher amp alternator in f-body size alternator?
I cannot use a truck alternator.....it brings the pulley up onto my procharger pulley.
Anyone make or sell a alternator that uses the smaller car-size alternator and more amps that doesn't cost $400? 140amps would be great!
Dude thank you so much. This may solve my issue! It looks to be a direct bolt on replacement for my 102amp. Main concern is making sure the housing is NOT the truck size housing, but the car size housing. For me with clearance issues on procharger pulley, that is everything.
At Advance Auto with 25% discount code it comes to $112.49 and its an AC Delco part. I wonder if this alternator is capable of living through a 7k pull on the dyno. Other than that, it should take care of my low power at idle problem I'm facing with the factory setup.
Info for the next guy:
