Radiator Recommendations
Greetings,
This morning my radiator blew up on my way into work. Damn these engines are robust; it ran up to 260 before I noticed it.... the steam blowing out of the hood was a clue too.
I'm looking for recommendations for a radiator. I'm looking at duralast, AC Delco, Spectra, OSC and Mishimoto.
An help would be appreciated.
I wound up just going with a Duralast. I have one in my `79 Firebird and have had no problems at all. I rarely buy duralast .... but what the heck it's only some aluminum and plastic, right?
And for like $117.00 off of HTTPS://WWW.Amazon.Com I guess I really cant beat it for price........even with the surgery required to fit..........
Good LUck with your replacement...........
Jennifur
Left Side (Drivers side facing driver) ? is a 3/4" water inlet/outlet for ? reason, not used in an F body............ The ? on the right side upper, is a screw in O ring aluminum cap that is where the coolant level sensor is supposed to go but does NOT fit, not even remotely close to being able to fit. So the cap had to go in and get tightened down and no coolant level sensor in the system at the moment.
All Aluminum polished radiator for 3rd and 4th gen F bodies
Interesting. Looks like a nice piece. I wound up getting a Spectra. My stock piece lasted 348,000 miles so I can't complain. It did however die a violent death. The neck area blew itself to smithereens.
Not quite EXACT fit, but with some basic moderate skills in auto repair and fabrication you can get this to fit. So for the $117.00 I paid with shipping to my door I cant complain even with having to do some work to it. Now its like you have to whoop the car silly to get the temp needle on 102 plus degree days to even move upwards to 185.
Glad you worked out your issue and if I got 350K miles out of a plastic Radiator, I would not complain either. Thats actually impressive but just knowing an all aluminum one would have lasted about 1 million miles or 850K at least for 117 dollars I wont compliain either. Mine busted and cracked at 122 k miles. for what thats worth.
Have a great one!!!
Jennifur
