Power Steering Pump for Hydroboost?
Not sure if I'm asking at the right place but for my Chevelle/LSA swap I'm considering stepping up do a Hydroboost. The PS pump I got with my accessory drive is GM 84629501. It appears to be a 97-2013 Corvette pump. Would this pump be able to do hydroboost? Thanks!
Yes, this is a great place for that question, and it sounds like a fun build/swap! For hydroboost applications, we recommend increasing the pump's pressure capacity over stock to ensure that the pump can provide adequate power for both the steering assist and braking assist together when needed. How much pressure will depend on your vehicle setup and how you intend to drive the Chevelle. We offer new pumps that are modified for this purpose, or we could rebuild your current pump and make the necessary modifications to ensure the pump is properly tuned for the car's steering and braking needs. We're happy to field and any additional questions.
chevmankiwi (05-01-2024)
LS1 pump mod
[QUOTE=steering_experts1;20290602]Yes, this is a great place for that question, and it sounds like a fun build/swap! For hydroboost applications, we recommend increasing the pump's pressure capacity over stock to ensure that the pump can provide adequate power for both the steering assist and braking assist together when needed. How much pressure will depend on your vehicle setup and how you intend to drive the Chevelle. We offer new pumps that are modified for this purpose, or we could rebuild your current pump and make the necessary modifications to ensure the pump is properly tuned for the car's steering and braking needs. We're happy to field and any additional questions.[/QUO
Hi there
Im interested in same thing.
I'm trying to fit an LS1 into a 1984 C20 and I've come up against this hydroboost, never heard of it before I am interested in using factory LS1 power steer pump so I'm asking what is your company that mods pumps to suit
Regards Chevmankiwi
steerg experts1
Hi there
Regards Chevmankiwi
steerg experts1
Last edited by chevmankiwi; 05-01-2024 at 12:02 AM. Reason: adding name so hopefuuly they see it
That’s what I’m running my hydroboost on. I did install a separate return line back into the power steering pump sump. Run two separate return lines.
That way you don’t get any feedback into the returns when they share.
