99 RCSB - Turbo/4L80/McGaughys
For Sale1999 Chevrolet Silverado 1500
99 Chevy Silverado RCSB 4WD- Turbo: $7000 OBO. I wont be offended by offers. Let me know if there are specific parts you need. Not willing to go through the hassle of shipping though.
Bad- VERY Rusty. I stopped driving it due to rust. Has a ton of perfect/new parts, but it was a northern truck. I was planning on buying a surrogate truck and swapping everything, but due to current prices that's just not in the cards at the moment.
Good- Less than 1k miles on brand new suspension. EVERY piece of the suspension is close to perfect, lower/ upper control arms with ball joints, idler arm, pitman arm, tie rods, power steering etc. Mcgaughys 2" Lowering front spindles, new hubs. McGaughys 4" lowering rear springs. Over $3k in suspension.
New Brakes- Lines, calipers, pads and rotors.
Rebuilt 4L80 trans with new sprag gear and shift kit, 258mm circle-D 3200rpm dual disk lockup converter. Converter alone was over $1000.
Rebuilt Holeshot Borg Warner S372 Turbo.
Newer 4.10 gears with new posi unit in the rear (~10k miles).
Fuel System should be good for ~1200hp. I was only pushing ~15lbs on 93, but was planning on bumping that up with E85... never got around to it.
Has a stock bottom end 4.8, head studs, LS6 Cam with supporting valve train.
Currently not running, fuel tank straps broke. The motor ran when parked, but had some blow by. Ive got an extra 6.0 LQ4 shortblock I can throw in, but I dont know anything about it.
Hot Side Is KB Racing, fully wrapped. Not sure what intercooler.
Im sure Im leaving a ton out.
DOES NOT COME WITH THE TORQUE THRUST WHEELS!
No trades, need the cash. Make an offer. This is not a "I know what I have" situation. Willing to work with the right buyer. I work a lot, but will get back to you as soon as I can.
Clean title in hand. Thanks for looking!
Picture | Title | Part Category | Price | Part Description |
See above | Accessories | $1 | 4L80, Turbo Kit, Susp |
