Notices
Winchester Metal Works fabricated oil pan - Truck style (rear sump)
Engine - Internals
  • Engine - Internals - Winchester Metal Works fabricated oil pan - Truck style (rear sump) - New - All Years  All Models - Streator, IL 61364, United States
ALL ULL C is offline
    $300
  • Location Streator, IL, 61364, USA
  • Condition New
So I'm going to use a LS Next block again and really have no desire to add the Moroso pan rail extensions in order to use this (may go dry sump as well). This has two -10 drain bungs added for turbo drains that if you do not want to use you could just cap. I believe this also adds 1 extra quart of capacity, so dimensionally this pan is just like an OEM truck pan other than he adds that bump out towards the front for the additional capacity. So you will still use your OEM pick-up.
$300 + the ride. Paypal or Cash
Scroll down to LS Extra capacity truck style oil pan: https://winchestermetalworks.com/
*** Understand you will need to run a remote oil filter kit in order to use this pan as it does not have an OEM provision. The two AN fittings are supply/return. ***
Old 02-27-2024, 01:40 PM
ALL ULL C's Avatar
Bump.
Old 04-09-2024, 12:29 PM
ALL ULL C's Avatar
Bump.
Old 05-23-2024, 01:15 PM
ALL ULL C's Avatar
Bump.
