Misc Parts, C5, Valvetrain Tools, Etc...
For SaleMiscellaneous
Price
$1
- Location Atlanta, GA, 30313, USA
- Condition Used
prices include shipping unless noted... if you have any questions or need additional pics pm me
-Steam vent tubes... **SOLD**
-LS6 valley cover... the line tube has been cut short, it is still usable or could be removed/replaced, see pics... **SOLD**
-Valley cover knock sensor grommets, new, set of 5... **SOLD**
-C5 overflow tank... $45
-Front and rear leafspring clamps... $30
-Tial Q recirc base (1.5" outlet) and weld flange... $65
-C6 parking brake cable... $40
-C5 fuel return hose... $50
-C5 Z06 fixed antenna... includes short stalk, does not include fender grommet... $60
-LG cat delete pipes and 3" band clamps for 1 3/4" superpros... **SOLD**
-C5 rear cradle... $100 pickup only
-C5 Max Tech cover... $60
-Comp beehive valve spring micrometer (1.6-2.2")... $80
-Comp pushrod length checker... **SOLD**
-Proform valve spring compressor... $60
-2 crank pin kits... I only have one drill bit... $40 each, $60 for both
-OEM GM LS2 2bar MAP sensor... part #12615136, modified to fit directly into LS1/6 intake... $50
-OEM GM oil pressure sensor... part #12616646, new... $30
-CCW lug nuts... set of 20, not sure of brand but they came with my old wheels... $40
-LS valve seals (new) and BTR install tool... $25
-High grade rocker bolts for trunnion upgrades, hex head, used... $10 with any other purchase
-LS valve locks, used... $10 with any other purchase
-Relay to repair 01+ EBCM, new... free with any purchase
-C5 ashtray... $10 with any other purchase
-C5 parking brake boot, has a small hole on one side that might not be visible when installed... $5 with any other purchase
-C6 parking brake handle and boot... $40
-Battery relocation box for Optima yellow tops (battery not included)... $80
-MSD coil relocation wires in the following lengths measured from end to end, (1) 38", (1) 37", (2) 36", (2) 35", (2) 33"... also includes approx. 19.5' of MSD 8.5mm bulk wire... $75
-Taylor ceramic boot coil relocation wires... I had to use 2 sets (one with straight ends and one with angled ends) to make a set for someone else... the angled ends have the coil boots already attached (were not used), straight ends do not... lengths measured from end to end are 38" on the straight end and angled are (1) 36", (1) 35", (2) 33"... includes the boots/terminals for the straight ends, (17) wire separators, and 8' of fire shielding... $120
