AFR 245cc MAMOFIED cathedral ports heads, FAST 102 LSXr MAMOFIED intake & more!
For SaleEngine - Internals
Price
$4,500• OBO
- Location Cornelius, NC, 28031, USA
- Condition Used
looking to sell the top end induction package off my 434ci LSx. heads & intake were all spec'd & worked on by tony mamo. aside from the original spec's these heads were built with - they have the 10mm rocker bolt upgrade, tonys porting (heads & intake) & milled to 70cc by him. i installed new valve springs at the end of last season. the intake has all new internal seals for the runners and a new seal for the 2 halves (i also have an extra seal i will include). holley fuel rails included. rockers are 1.7 yella terra's that require the YT specific valve cover seals to clear the stock valve covers.
im not looking to spilt this up since its all ported and matched.
afr 245 mongoose head specs (from afr site)
8mm Bead Lock Intake Valve, 2.165" x 4.900" Overall Valve Length
8mm Bead Lock Exhaust Valve, 1.600" x 4.900" Overall Valve Length
PAC Racing Spring 1.270" OD Hydraulic Roller Dual Valve Spring, 155 lbs. on seat, .650” maximum lift, Max RPM 7000-7200
7° Titanium Retainers 1.245" O.D x .885" I.D x .655" I.D
7° Bead Lock Valve Keepers
Viton Valve Seals .600" O.D x .495" I.D
Hardened Valve Spring O.D Locator 1.380" O.D x .570" I.D
Ductile Iron Intake Valve Seats 2.200" O.D x 1.750" I.D x .375" Deep
Ductile Iron Exhaust Valve Seats 1.650" O.D x 1.350" I.D x .375" Deep
8 mm Bronze Valve Guides .502" O.D x 2.100" O.A.L
located in Cornelius NC, can ship at buyers expense but would prefer local pickup
