LS CDI Box ignition and coil kit NEW
For SaleEngine - Electrical
Price
$599
- Location Lanexa, VA, 23089, USA
- Condition New
Complete Aces brand LS CDI system new in box. Retails for $1499, I decided I did not need it for my mild build.
ACES EFI Full House™ CDI Ignition System
ACES EFI Full House™ capacitive discharge ignition (CDI) system is the most powerful ignition system on the market. Designed for coil-near-plug applications, the Full House™ seamlessly integrates with ACES EFI engine management systems such as Jackpot™ EFI, factory GM LS platforms, and most aftermarket EFI systems. The Full House™ CDI ignition system offers unrivaled spark energy and dependability making it ideal for street/strip, full race, or any other high-performance application.
The Full House™ CDI ignition allows for adjustable spark energy output, making it the perfect ignition for street cruisers and all-out race cars alike. Engine combinations with high-compression or power adders where extreme cylinder pressure exist require more spark energy for complete combustion. Lack of spark energy means you’re leaving power on the table. In the past, this meant you needed an ignition system with a constant output powerful enough for the combination. The versatility of the Full House™ allows you to turn down the output for the times you don’t need extreme spark energy and turn it up when you do. This system is perfect for the hardcore street/strip combinations being used in the super-popular drag-and-drive events.
The Full House™ is as safe as it is versatile, with built-in protection for accidental battery connection reversal and over-temperature protection, all in a water-resistant case. Troubleshooting is easy with LED diagnostics that can identify a problem with individual coils should one come up.
Whether you are building a budget beater or a boosted racing car, ACES EFI’s Full House™ CDI ignition system has the technology and advanced features to meet your needs, in an easy-to-install, easy-to-tune package so you can take your ride to the next level!
ACES EFI Full House™ CDI Ignition System Features
The most powerful CDI ignition system available
32-bit Power Architecture® based MCU and IC driver chips for automotive powertrain applications. This technology manages input/output signals and voltage, and RPM faster and more consistently than the competition
200-750 mJ spark energy output
Robust shielding for anti-interference, high-stability hardware and software design
Real-time programmable ignition curve
Eight-channel ignition control with over 750mJ spark energy
OE-spec water-resistant housing
High efficiency alternating current (AC) power delivery over 50 kV output voltage to drive ACES performance ignition coils
Reverse battery protection
Primary voltage over 565 volts
Spark duration of greater than 300 microseconds
Operating voltage from 6-22 volts (6V minimum to start vehicle, 22V max operation)
Direct plugin to ACES Jackpot EFI systems
Compatible with most EFI systems using 5V or 12V drivers
Includes 8 high-power GM LS-style ignition coils
