Crimp tools
Crimp tools
While the tools in bold I'm pretty sure will work for the following terminals, can I get away with using a 3189CT for the Micro-packs instead of a 3191CT?
Can I use a 3305 MPCT for the 56 series and Ducon 6.3 terminals below?
Crimp tool 3191CT.... can I use a 3189CT?
15359002 - (18awg) Micro-pack 100W (no seal)
12160552 - (20-22awg) Micro-pack 100W (no seal)
Crimp tool 3305 MPCT
12110853 - (10-12awg) Metri-pack 280 (no seal)
12176854 - (10-12awg) Metri-pack 630 (no seal)
Crimp tool 3181CT... Can I use a 3305 MPCT?
12010966 - (14awg) 56 Series (no seal)
Crimp tool 3306 MPCT... Can I use a 3305MPCT?
12147474 - (10 awg) Ducon 6.3f with 15324996 cable seal.
Also for Super seal 1.0 terminals like 3-1447221-3, 3-1447221-4, and 3-1447221-5.... can I use the 3189CT / (Same as a Delphi 1215597) for those as well?
I have a Sargent 3189CT already, as well as an IWS-1424B
I have a Daniels DMC AF8 M22520/1-01 with THA1 for Deutsch Solid Contact Terminals
Just need something that can handle 10-12awg terminals above and a micro-pack 100W crimper if the 3189CT doesn't work on those.
This should do it for the micro-pack 100W
https://www.bmotorsports.com/shop/pr...roducts_id/364
For 10-12awg, going to give the Keenso Open Barrel Crimping Tool, 22-10AWG on amazon a try.
Delphi 15155975 (Same as Sargent SP2084) look to be ratcheting for 10-12awg, also there is non ratcheting Sargent 3302.
Sargent 3191CT: Is a ratcheting crimper for Micro-Pack 100/ 100w, Micro-Pack 064, and there's the cheaper Sargent 3303 64 CT cheaper non ratcheting.
Might go with the 3302 and 3303 64CT since I don't have many terminals of this type to crimp.
