Notices
Low mileage 2001 Camaro SS for sale
2001 Chevrolet Camaro
  • 2001 Chevrolet Camaro - Low mileage 2001 Camaro SS for sale - Used - VIN 2G1FP22G412112773 - 40,247 Miles - 8 cyl - 2WD - Automatic - Coupe - Red - Fallston, MD 21047, United States
RED 01 SS is offline
    $20,000
    • OBO
  • Location Fallston, MD, 21047, USA
  • Condition Used
  • VIN 2G1FP22G412112773
  • Trim Z28
  • Mileage 40,247
  • Engine 8 cyl
  • Drive Type 2WD
  • Transmission Automatic
  • Vehicle Type Coupe
  • Exterior Color Red
I'm the second owner of this car but have owned it almost her whole life. I bought this car used with 3000 miles on it in 2002. Everything works as it should on the car and has been very reliable over the years. It has been garage kept under a cover its whole life. I know I'm going to regret selling it but I have no time to enjoy it. The car just sits in the garage. I hope you can see by the pictures how good of care I have taken of her and hope the next person does the same. Here is what has been done to the car over the years. Let me know if you have any questions. Thanks for looking!
Red with Black leather interior
T Tops
Originally a six-speed car converted to automatic
400 RWHP on motor 550 RWHP on nitrous
ENGINE
Original LS1 347 block
Powerbond Underdrive pulley
Stock Crank
Scat forged rods
Wiseco forged pistons
Custom Ground Comp Cam
243 heads
Beehive springs
Chrome molly push rods
LS6 intake
NGK BR7EF spark plugs
340 LPH in tank fuel pump
Engine was built and installed by Jeff Lowry at PSI
EXHAUST
Pacesetter 1-3/4 coated long tube headers with stage 8 licking header bolts
Pacesetter Off-road Y Pipe
Magna flow cat back system
QTP electric cut out
TRANSMISSION
4L80E Performance transmission, manual valve body, D1 Transbrake with blue plate clutches. Transmission was built by A-One Transmission Performance Specialist.
B&M Pro ratchet shifter
Circle D Pro series billet torque converter 245MM single disk lock up 3800-4000 stall
TCI Flex Plate
REAR
Moser Ford 9” with 3.73 gears
Eaton Truetrac posi differential
Moser 31 spline axles
SUSPENSION
Viking Warrior double adjustable coil overs 14” 300# front and 12” 150# rear springs
Spohn body mounted torque arm
SLP Lower control arms
UMI Adjustable pan hard bar
UMI subframe connectors
NITROUS
TNT Power Ring Nitrous Wet Kit Currently on a 150HP
NOS Cheater solenoids
Nitrous Outlet nozzles
Bottle heater
Remote bottle opener
Billet nitrous filter
Fuel pressure safety switch
Ashtray switch plate (ARM, PURGE, HEATER, OPENER)
Comes with lots of different jets for other HP levels
ELECTRONICS
Lingenfelter LNC-2000 Timing retard controller and adjustable RPM limiter
MSD RPM Activated Window Switch
Line lock
AEM pillar gauges for Wideband AFR and Transmission temperature
Show and Go license plate mount
STEREO
JVC Double din head unit with back up camera
10” Kicker subwoofer with custom sub box
Kicker 150 watt sub amp
Infinity speakers
WHEELS AND TIRES
Billet Specialties Street lite wheels 15X4 front 15X10 rear
26x7.5-15 Mickey Thompson Sportsman front tires
275/60-15 Mickey Thompson ET Street R rear tires
EXTRA PARTS
2-17X11 & 2-17X9.5 American Racing Torq Thrust II polished wheels (F body fitment) with 275/40-17 Mickey Thompson Sport Comp front tires and 315/35-17 Mickey Thompson Street SS rear tires
Factory 10 spoke wheels (no tires)
Strano Performance 1.2 inch lowering springs (fronts are mounted on factory struts)
Factory front sway bar
Original stereo with dash kit
Billet grille
Old 06-24-2024, 12:03 PM
RED 01 SS's Avatar
Post is now working
Old 06-27-2024, 05:04 AM
lafnatu's Avatar
WOW! That's a great build and an amazing price. GLWS
Old 06-28-2024, 05:39 AM
RED 01 SS's Avatar
Old 07-02-2024, 11:52 AM
RED 01 SS's Avatar
Bump ttt
Old 07-03-2024, 02:12 PM
RED 01 SS's Avatar
Here is some video clips
Exterior
Interior
Old 07-05-2024, 07:59 AM
Htech's Avatar
Originally Posted by RED 01 SS
Looks amazing GLWS
