6L80 torque converter clutch drag?
Has anyone had any problems using an aftermarket converter in their 6L80? I bought my converter used, and it has about a 3600 stall. I'm thinking the clutches are worn out, because it won't stay locked up. I "zero'ed-out" the programmed slip in the tune, but it's still slipping about 50 rpms. It makes a horrible rumbling sound, and sometimes causes the car to shake. It does this at idle, with the trans in gear, and sitting at a stop. It also does this while moving on the highway, or at slower speeds, when the converter is supposed to be locked up. It doesn't do it in park, or very much in neutral. Circle-D said they can re-buid the converter, but I don't know if that alone is going to fix the problem. I'm thinking there needs to be more pressure going to the lock-up clutches to keep them either fully locked, or fully unlocked.
My 4L80 had a converter clutch drag, but it only did it for a second when taking off from a stop. After that, it was smooth. Do I just have bad luck with converters, or is this a common issue?
