Big injectors and idle quality
Hi guys, I understand some injectors have a straight/pencil stream and some have spray patterns that atomize the fuel better. I have a Holley standalone and a 1-1 fpr and running flex fuel sensor/e85 with my turbo setup, pretty standard stuff. Currently have Deka 80lb injectors, they idle just fine but I am out of fuel. I have 120lb FIC injectors which I believe atomize better and would get me to 700hpish. But what if I get some Bosch 210s like what VS Racing sells? I would be able to set my base fuel pressure lower to get the most out of my single Walbro "Hellcat" pump. But would I wreck my idle quality?
Second part of the question, what are your favorite big injectors? Am I missing an obvious go to injector?
"I have a Holley standalone".
Which one?
Terminator X has to use high imp injs.
So, if you step up, be sure that's what you get.
Which one?
If you are looking for drivability, the ID injectors are the go-to - load in their published injector characteristics and a lot of things get cleared up.
I probably have 5 sets of injectors in my garage and I run the 1050 ID's for the drivability.
The following 2 users liked this post by NoGo:
Old Buzzard (06-26-2024), Woodylyf767 (Yesterday)
The Terminator has the inj end angle feature.
Take a look at that when tuning.
There's some discussion as to its accuracy in the calcs.
Here's a link to such.
Let me help you with Injector End Angle. - Holley Performance Products Forums
120s should net you 1000+ at 60psi base and 90% DC. 80’s should go 600++ if they are plumbed efficiently w 60+ base and good voltage. A lot of times the plumbing is poor, or the pump can’t handle pressure well. The in-tank walbro style are known for flowing poorly at higher pressures.
Be sure to look at your voltage above 6k or so too. Super common for OEM alternators (especially cheap auto store remans) to drop off around 6k. Then come back online at lower RPM. So if you don’t data log, many don’t know they have a huge voltage drop at high RPM.
210’s will idle e85 just as well as the 80’s in my experience. No reason not to go big and buy once IMO.
The following 3 users liked this post by Forcefed86:
HP academy tuned in podcast has the injector Dynamics guy going into depth. I believe in it they say that the OEMs (dodge) uses ID on some of their higher trimmed cars
