Ls1 timing tuning
Old 06-26-2024, 11:07 AM
alexisz28's Avatar
Default Ls1 timing tuning
I have a 1988 camaro with ls1 125shot of nitrous runing 110 octane is their anybody that can guide me on turning the timing up i have looked at previous tunes he has sent me but all timing tables look the same not sure what he moves the timing on
Old 06-26-2024, 12:49 PM
LilJayV10's Avatar
"Typically" you remove 2 degrees of timing for every 50hp of nitrous. Race gas you can probably be less conservative.
"Typically" catheral port heads like 25-27 degrees of timing
Without a dyno or at the track, it's hard to know how much timing is enough and what is too much.
Regardless, reading spark plugs is the only way to know for sure.
Old 06-27-2024, 01:03 PM
alexisz28's Avatar
Its actually already tuned my tuner wanted a spark plug reading to see how buch more timing he could add. just that i sent him the pictures but he hasnt got back to me yet. i would up the timing my self but im not sure on what table he lowered it on both spark tables show 28 degress but data log shows 26 at wot my tuner lives in another state
Old 06-27-2024, 01:11 PM
LilJayV10's Avatar
There are several tables that will add/subtract timing from the base spark table. IAT being the most common.
Old 06-27-2024, 07:47 PM
alexisz28's Avatar
Looks like i see how he took the timing out looks like he used the fuel table in spark its called afr spark advance correction
Quick Reply: Ls1 timing tuning
