5.3 to 5.7 rebuild
5.3 to 5.7 rebuild
I need help guys. This is my first full rebuild of an LS motor that i have to pick all the internals. Ive assembled plenty of engines, just never went through the process of picking pistons, cams and valves. This is a 2005 Silverado 1500 4x4 and i use the truck as a truck.
Im just wanting a basic rebuild but bored to 5.7. choosing 5.7 because i dont want to swap the transmission as well and im feeling nostalgic for an LS1.
My goals are simple, rebuild the 5.3 to a 5.7 but retain the reliability and drivability, im not chasing horsepower or redlines, but i want LS1 numbers, 350hp and 350tq. That'll be plenty for what i want and need.
Here are my questions, do i need a new cam profile to match the bigger displacement, if so, what should i go for? I want it smooth, not lopey or thumpy or whatever the kids say nowadays. Im totally ignorant to cam specs, so i definitely need help with this one.
What about heads? Should i keep my current heads? I assume mine are 706, but i havent scraped the gunk off to check, but the free long block i got has 706 heads, i dont think mine are not cracked as i have no coolant loss issues, just valve stem seals, but i have no history on the donor block except "it ran when my student swapped to a 6.0". Do i need to get different heads? If so, what will give the most reliability and efficiency? I plan on fully rebuilding whatever head i go with, another technical thing im kinda dumb on.
Finally, what pistons should i go with? Any brands to stay away from? Im thinking the hypereutectic pistons should be perfectly fine. I dont see a reason to spring for forged. Should i go with flat top or stay with dished? I know enough that the piston design can change compression, but i have no idea which way i should go..
I need to have my pistons chosen, and the block and heads stripped for the machine shop to do their part. Any help is appreciated, i can build the engines and throw parts together correctly, but chosing the right stuff is where i need help.
Thanks alot.
TLDR: Im a dummy and need help picking the correct pistons, cam, heads and valvetrain goodies to bore my 5.3 to a 5.7 and rebuild it.
Thanks alot.
Iron 5.3s have enough meat to bore to LS1 specs. Then just use std. LS1 pistons.
Keep the truck heads, but be aware that you'll be getting a smaller chamber by about 6cc
Your compression will go to 10.99:1
If you can get some 243/799 heads the compression would be 10.44 due to the 65cc chambers on them.
The stock LS1 cam is pretty much the same as the LQ9/late LQ4 cam at 196/201, .467/.479 116 LSA.
Between all this you will have a smooth and torquey 5.7 truck engine
The following 3 users liked this post by G Atsma:
Any other heads to look at? I started browsing marketplace and found a pair of LS1 241 heads for 200$ with rockers and covers. Also found a pair of bare 243s for 200$, seems a little too cheap. But i dont know.
The 5.3 706 heads are better than the LS1 heads because of the smaller chamber and slightly better ports. A good bowl blend and multi angle valve grind will improve them a lot.
The LS1 heads are usually not recommended.
As I said above, either keep and slightly mod your 706/862 heads (hey, you have them already...) or get some 243/799 heads which have better ports and larger chamber.
No other heads need apply here
The following 2 users liked this post by G Atsma:
demonsmokr (06-28-2024), strutaeng (06-27-2024)
What do i look for in regards to damage when buying used heads? He agreed to 150$ for the pair. Why do i feel this is too good to be true? Am i just jaded from numerous bad experiences on facebooks and i cant tell when someone is selling a good thing for cheap?
Only thing i know to look for is pitting from nitrous, what else do i need to look for?
G Atsma (06-28-2024)
