Oil pushing out of the Oil Filter Seal.
I did heads cam swap om my LS1/M6 Trans Am. I replaced the oil pump, pickup tube ring, barbel, timing chain, cam plate, front and real covers and crank seals, plus all the other assorted pieces to do the swap. I started the car and it read no oil pressure. Took a valve cover off, and not all of the rockers had oil on them. Check under the car there is a small puddle of oil under the oil filter. You can see that its leaking from the seal. I swap it out for a wix filter same issue. When I swapped the filters there was a good amount of oil that fell out, like a normal oil change. So I would think the pump is working. The oil pump has been ported. I am not sure what would cause this issue.
Thank you in advance for the help.
I just went back out to the car sprayed the area with brake clean. It is leaking from the block off above the filter. It basically runs down the block goes around the filter and drips from it. I will have to change this gasket.
I will be ordering a oil pressure sender/switch to replace the original one and see if that helps. It worked before I did the swap, but who knows if I whacked it taking the intake off.
LilJayV10 (06-29-2024)
If I was the betting kind, (I'm not... I was a university statistics teacher in a past life) I would bet that those bolt holes are stripped, and/or that you will strip them in the process of changing that gasket.
Figure out what it will take to Heli-Coil them THE FIRST TIME. Not, slap-happy it, then come back on here whining about "it leaks even worse now GM sucks FelPro sucks everything sucks", and realizing you should have done that in the first place. Might, for example, take a right-angle drill attachment and maybe wizz-wheel off the drill bit acoupla inches so it fits up in there. You'll have to inspect carefully beforehand and make those kinds of judgment calls and then prepare the proper prep.
And to add to this, those block-off plates will warp very easily if the bolts get overtightened. Check it for flatness on a flat plate, or use your wife’s granite countertops…just don’t tell her about it.
