O2 sensor wiring
I need some help from a bigger brain than mine.
This is my first foray into an LS engine swap. 5.3 L installed into a 1990 300zx. The engine came from a 2003 Tahoe that was wrecked. I am learning as I go. Zero experience with LS electronics prior to this. Engine fires and runs ok, but I need to get the O2 sensor reading to do any kind of tuning on it. I have HP Tuners hardware that I can use to pull data. Future hope to figure out how to set up Speed Density tune, but that is for later.
I cannot get my o2 sensors to read at the pcm. Aftermarket harness. The current config is as follows, but the wire colors don't match factory, all are solid colors:
harness driver side : pur 12v pink 1v yel 4v tan gnd harness pass side: purp 12v pink 1v black 4v tan gnd
o2 sensor is 4 wire black black blue white
I do not know what year my pcm is from
I crawled under a suburban (2015) and measured harness outputs, and they were within .3 v of the results on my swapped car.
I matched up the connections on my car to what was on the working suburban as follows;
driver: blacks to yellow and purple, white to tan, blue to pink
pass: blacks to purp and black, white to tan, blue to pink
HP Tuners reports .45 v on both sides bank 1 sensor 1 bank 2 sensor 1. no fluctuations other than .44-.45v constant.
tested o2 heater wires, got 7.5 ish ohms on both. torch tested blue and white wires, and got voltages from .1-.9 ish.
I have tried multiple wiring configs, and nothing works! Please help me.
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
New guy, here... ;-) I have watched both of the attached vids. I have ordered the Bosch part numbers, I will post back here upon receipt and installation. Thank you for helping me, I really appreciate it! I have been trying to figure this out for weeks.
-d3
-d3
