Has anyone broken stock axles?
Old Yesterday, 06:19 PM
Mustang Hat'r 2's Avatar
Default Has anyone broken stock axles?
I'm going to build an 8.8 on the cheap. I have no use for my stock rear so I'm going to use the axles etc from my 10 bolt. My question at what point will I start breaking them on the street? I currently have HCI car running 9lbs of boost making 600ish to the wheels, M6 trans. Stock 10 bolt is still in there and working but its leaking at the tubes so I know I'm flexing it.
Old Today, 07:20 AM
91 Z28's Avatar
If you're already planning on building an 8.8 "on the cheap" why not just put some 31 spline axles in?? That said if you're just running a street tire and spinning you should be fine on stock axles, it's when you start hooking is when problems start rising
Old Today, 07:50 AM
by cheap,
ranger 8.8 with 3.55 gear LSD $220
Bearing kit $80
torque arm mount $70
Rear cover $65
$366 out the door, my rear end is free and don't want to store it.
31 splines add $1125
center section rebuild with gears $500
Custom axles from Moser etc $475
Big ford end $160
Thank you for the response, just want to make sure my logic is correct.
Quick Reply: Has anyone broken stock axles?
