How bad is this crack?
Hello LS world,
I am building my first ls3 engine ever. I just got the block back from the machine shop. I told them to make it that a 5 year old could put it together. Practically do all the heavy labor or checking clearances etc. I got home and placed the engine on my work bench and saw this crack! I am not sure if the machinist caught this! How bad is it? Is it repairable or am I SOL? I'm a little upset since I paid them a little north of $1400. The crack is on the front side I believe. The side where the cam retainer plate is on.
Do you have a friend with a TIG machine ?
I'd melt it back together, dress it flat with a file, and chase the threads.
The following 2 users liked this post by Full Power:
strutaeng (Today), wannafbody (Today)
Yeah, that can be repaired without too much issue, TIG welder and install that bolt a bit loose.
Looks like someone forgot that bolt when removing the oil pan, and tried prying the pan off anyway.
That bolt hole is not structural, and the crack doesn't extend into any liquid, so I wouldn't worry about it.
wannafbody (Today)
May want to drill a shallow hole at the known end of the crack before welding. This will help prevent the crack from continuing...Never mind, looks like it tracks all the way to the other bolt hole. Zoomed in this far, it's hard to see what that bolt hole at the side is/does.
cut a chamfer following the crack so the weld can penetrate further.
