Clutch disengagement issues
Finally got my lq9/t56 project on the road yesterday. Drove it to work today and while looking things over I noticed the clutch reservoir was slightly lower than I would have liked to see, so I topped it off. Since then, I can no longer disengage the clutch. Bled the system countless times and got no more air out.
I can shift into any gear with the car off, but not running. If I put it in gear while off then start it, the car tries to roll, showing the clutch is still engaged slightly.
Ls7 clutch
New stock slave, maybe 25 miles on it now
Tick master cylinder
My plan is to tow it home and pull the trans. Maybe a failed/bad slave, bad pilot bearing(maybe I damaged during install?)
Is it ironic timing with adding fluid to the reservoir?
Please help
Ls7 clutch
Please help
No fluid anywhere that I can see leaking. But like I said, it's barely been driven.
