General LSX Automobile Discussion Non-technical LSX related topics.
Help. Can't locate source of steam coming from passenger side
Old Feb 11, 2026 | 05:55 PM
BrooseLee's Avatar
Default Help. Can't locate source of steam coming from passenger side
I have a 98 Camaro Z28/SS. First car I ever purchased. It's been a project getting it back to its glory days. My brother and I have had various issues that we have been able to diagnose/fix, but this one is eluding us. We can't seem to figure out where the source of this steam is coming from. Hopefully the videos can help someone help us.
From Engine Bay
From Interior
Old Feb 12, 2026 | 05:18 PM
LS1Formulation's Avatar
My guess would be the steam ports on the back side of the heads. Either the line is cracked or the small gasket that goes under the fittings sprung a leak. Get a coolant pressure tester and see if it will hold pressure. Likely it will not.
Old Apr 11, 2026 | 10:22 PM
Terry1977's Avatar
I am having the same issue only instead of steam, I have a leak and it is on the passenger side. The heater core hoses and firewall are dry. Is this a pain to fix?
Old Apr 12, 2026 | 05:28 AM
Austin Phil's Avatar
Check for leaks at heater hose connections at engine side of firewall. If no leaks there, Looks like a leaking heater core. Click on below for heater core replacement:
Old Apr 12, 2026 | 05:42 AM
Run some leak dye in your coolant and get a small blacklight to look for the leak. If it is leaking from one of the steam ports on the back, it's not a difficult job to fix. Pull the intake and they're right there.
Old May 11, 2026 | 07:50 AM
fann's Avatar
I'd check is the intake manifold gaskets.
Old May 11, 2026 | 01:30 PM
There is no coolant running through the intake on an LS engine.
Old Yesterday | 12:41 AM
fann's Avatar
Ahh, sorry, my bad
Old Yesterday | 10:36 AM
Tommy42088's Avatar
Running pretty rough too, looks like its misfiring as well.
